I have an AEG lavamat 50600which takes ages to start and think this is because the door catch isnt engaging properly how do i rectify this ?
If i wait and then push the door firmly the machine will then start
  • Washing Mach... Master
  • 17,130 Answers
This is due to the fact that the door switch is faulty and the lock does not switch the circuit. You can use some switch cleaners to improve the contact, if not the door switch must be replaced.
Click on Door switch
Posted on Jan 17, 2013
  • 1294 Answers
SOURCE: AEG lavamat
For user's manual: Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, & your manual is on line. Wait for at least 3 minutes after the wash is complete, to open the door; do not force the door. The door will not open immediately on the wash being completed.
Posted on Dec 25, 2007
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
SOURCE: I have an AEG Lavamat 16820 washer dryer and the
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
Posted on May 12, 2009
Cd code, and clicking sound from door
does the door lock if not the door catch is faulty
Nov 27, 2011 | AEG Lavamat 72640 Front Load Washer
Aeg lavamat error 40e
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board.
Feb 04, 2011 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 74620 shows a Cd error code. Can you tell me what problem this indicates.
CD means door lock is defective. this may be due to the door catch broken or even the main board being defective.
Nov 23, 2010 | AEG Washing Machines
AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Nov 12, 2009 | Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
I have an AEG Lavamat 16820 washer dryer and the door wont open any ideas
May 04, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG lavamat
Dec 25, 2007 | AEG Lavamat W1050 Front Load Washer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
