Drayton digistat 2
Hi. I have a Drayton digistat 2 thermostat (NOT +2 or RF- old square version) and a worcester 28i junior combi boiler. I have had to replace the batteries in the thermostat and since then it will not turn the boiler on. Everything else seems to be working- I have hot water, canprogramme the thermostat for temp and time but it just does not seem to be connecting with the boiler. Please note: There is NO RECEIVER, unless it is actually inside the boiler itself. Many thanks in advance.
4 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Posted on Oct 31, 2009
Macklintok
  • 122 Answers
SOURCE: Is it possible ot obtain
You can get the Manual here:
Drayton Digistat RF2 wireless room thermostat
Posted on Sep 16, 2010
SOURCE: MY WORCESTER COMBI BOILER 24i
when i open the tap for hotwater i can see only the flashing light on and not hotwater at all the guy changed the fan but after changing its no use waste of money i still have this problem i dont want to spend more on it can some one let me knolw the problem so that i can fix ir my self .
Posted on Jun 23, 2011
How do I reset pilot light on greenstar28i junior combi
found this on how to reset it hope it helps...
https://forums.digitalspy.com/discussion/2014658/worcester-greenstar-28i-junior-boiler-fault
Mar 01, 2018 | Water Heaters
Worcester 28i junior , won't come on, I have no heating but have hot water
First check, in there a room thermostat fitted. If not look at the boiler timer if a circular clock type move the side slider to gentral position and set the timed pins do that when the clock face rotates the pins operate the boiler heating on switch OR if a digital type press the button marked mode to so that on the display there indicator bar moves to the on position.
Dec 11, 2017 | Water Water Heaters
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
How to programme rc2 british gas thermostat
The British Gas RC2 is a re-badged Drayton Digistat and I managed to find installation and operating manuals for that at www.gasapplianceguide.co.uk
Go to the section 'Lost your instructions' and look for Drayton 2F & 3F Digistats (earlier type) for a downloadable copy of the manuals.
Following them got my RC2 up and running though it was a bit fiddly at times.
Hope this helps.
Oct 27, 2011 | Honeywell Programmable Thermostat Heater
Drayton digistat 2 thernostat manual an elderly neighbour can not set it and has lost manual
Go line to Drayton site and download a manual for him and follow it to the T. It to hard setit out. Ken'Repair
Jan 22, 2011 | Heating & Cooling
Worcester bosch greenstar junior 28i approx 2 years old. timer is not working it does not fire up at set time could it be something simple or do i need a new timer.
Hi, this is Worcester, Bosch Group.
Our technical team can help with enquiries - please call 0844 892 3366.
We look forward to helping you.
Mar 29, 2010 | Heating & Cooling
Oct 27, 2009 | Heating & Cooling
My Drayton Digistat RF3 boiler control is not working. The thermostat module indicates it is sending a signal, but the unit beside the boiler has a red alarm LED lit. I've removed the batteries and turned...
I found that this solved the problem hope it helps you too.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Nov 04, 2008 | Heating & Cooling
Boiler Thermostat
In desperation, I trawled the internet and am pretty sure that these are manufactured by Drayton, either a Drayton Digistat +2 or Digistat +3
Try this page http://www.gasapplianceguide.co.uk/drayton_central_heating_controls.htm
Good Luck!
Iain
Oct 02, 2008 | Hardware & Accessories
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
