Question about Whirlpool AWM5145/2 Front Load Washer
How will i know if i need new brushes
Doing programe but stops when it comes to programe A and won;t drain
Brush roll stops intermittently while using
I don't know what make or model bu on many vacuums that means you need a new belt.
Jan 28, 2018 | Vacuums
The washing machine has just stopped , it's still full of water ?
if its a model with an conventional mechanic/electric program clock you must look if you can hear the program clock is working, and if it is then i think a auto stop in a short worn carbon brush that can be activated to protect the armature for damage of the outcoming spring from behind the brush cannot come between one of the brushholder and commutator. if the programclock is not run then push out the power off and set the clock to pumping draining of the machine thats an other function the function of the pump, if your machineis a budged machine between 4 and 7 years , do not repair but in most cases marketing technical you come from one problem into the next in a short time, replace the machine is the best option.
Mar 24, 2016 | Washing Machines
Will not turn on
Undo the black plastic caps, one on each side. You probably need new carbon brushes. Remove them carefully and note that the brushes will only fit one way there is a blocking stop on the inner edge of the brush holder, you can see it with a torch when brush is out. Line the chamfered off corner of the new carbon brush up with the blocking stop. On one side it is at the back at the top and the other at the back at the bottom ( I think )
Nov 21, 2013 | KitchenAid Kitchen Aid STAND MIXER 5qt...
Bissell bagless 6583 brush won't turn after new belt
Sorry to hear about the difficulty with the brush. If your brush does not turn by hand freely, then your brush needs to be replaced.
Here is a quick link to order a new brush:
http://www.bissell.com/parts/?id=9143&sc=part&partid=17048&cid=ccsocial
Mar 20, 2013 | Vacuums
GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
Aug 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Fixing lg whasher
??? not enough information, what do you mean by this? the clothes are still wet when they come out the machine does not spin at all?
the machines have a set time to drain before they spin usually three minutes if the water has not dropped below a level before the set time the machine will stop, check the drain
Clothes begin to get wetter than before? how old is the machine motor brushes usually last 2-3 years depending on usage when they wear down the parts of the program that put the most power through the brushes can fail first (Spin)
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Washer fills and will drain but not wash.
i remember click is the motor relay engaging.
reason for no rotation may be the motor brushes.
take back panel off, disconnect motor elec plug, undo fixing bolts and withdraw motor and you can then check brushes. also check condition of commutator - series of copper segments brushes run on
Sep 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
WD62 is not spinning even after chaning new carbon brushes
when u changed the carbon brushes did u move the little metal pin to free the carbon off it must be able to come out then in with ease if not do this if u did then if the carbon brushes have got too low then it will have more then likely damage your motor m8
Feb 09, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Whirlpool AWM5145/2 Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
