Question about Frigidaire Dryers
Frigidaire dryer shuts off
Frigidaire gallery series dryer GLEQ2152ES1 runs for 5-10 minutes and shuts off with dashes circling and flashing in the display screen...any idea what i should do?
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
SOURCE: how do I install the shoe rack in my frigidaire
You have to remove the lint filter and the part of the shoe rack that sticks out then fits into the slot when the lint filter would sit.
Posted on Jun 28, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: have a Frigidaire Gallery Series
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 21, 2010
Frigidaire front load dryer not drying all panel lights flashing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Frigidaire Dryers
I have a gallery series dryer and after a short time, maybe 20min, the dryer stops and all the lights on the right side start flashing
Good Morning Catherine Funk, thank you for your post!
From my understanding your Frigidaire dryer will start and stop after 20 minutes, also the lights on the right side start flashing. Could you provide me with your model number, please? You can usually locate it on the door frame of your dryer. With that information I can examine your control board and provide any further assistance. -Matt
Feb 22, 2015 | Frigidaire Dryers
I have a Frigidaire Gallery Dryer # GLEQ2152ES1. Bought it used. No probles for several months. Moved to a different location. Dryer works but not heat and shuts off frequently. I replaced the control...
Hello - Since you have previously replaced the control board and confirmed that the high temp sensor is working fine, unit may possibly have a defective sensor, heating element, power supply or a communication problem with the control board. I suggest contacting a professional to move forward accurately. The technician usually warranties their labor just in case something else may turn out to be the root cause of your initial problem.
Oct 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Have a Frigidaire Gallery Series Model GLEQ2152ES1 dryer. It is approximately 2 years old. It has started beeping constantly and the lights on the right are constantly blinking. The only way to get it...
Something might be stuck in the bottom of draining pipe. Must take bottom panel off remove clamps to platic hose . Then stick your fingers and feel for any loose change or torn clothes that pluged it.
Mar 05, 2011 | Frigidaire GLEQ2152ES Electric Dryer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire electric dryer GLEQ2152ES1. Dryer starts for a few minutes then turns off displaying a code of dr on the display screen. What is it and how do I fix it. Also need all the codes or where to get...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My Gallery series dryer shuts off.
Check your lint screen. If you do not get a complete "lint pattern" you probably have a clogged or partially clogged vent which will cause your dryer to overheat and prematurely shut off. Clean your vent and you'll return to normal operation. If you have a vertical vent (goes up through the roof) get a proffessional to clean it. Dryer vent issues are the #1 cause of house fires according to the U.S Department of Consumer Affairs. Over 16,000 per year.
Nov 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
