Question about Philips 32PF9964 32 in. Television
Phillips 32FD9944/01s - sound but no screen
Had this plasma for over 3 years and suddenly when switched on it likes to play te sound but i get no picture - can anyone tell me what has likely happened ?
  • marc craddock Jul 11, 2007
    Thought that might be expensive - Bugger !!
    Thanks for the advice
  • 4 Answers
Check out this site http://www.avforums.com/forums/plasma-televisions/400763-philips-plasma-repair-advice-thread.html It`ll provide some answers if not all!
Posted on Aug 20, 2009
  • 67 Answers
Your set may have blown its y sus board and i know the x sus board is part of the plasma display panel either way your looking at a very expensive repair if your not warrantied
Posted on Jul 11, 2007
SOURCE:
Phillips flat screen TV
It sound like its fly-back transformer side circuit fault. This is not a user repairable fault. Contact any service technician.
Jun 10, 2013 | LG 42PC3RA 42 in. HD-Ready Plasma TV
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma screen suddenly went out
its a lcd ? replace the lcd lamps or the inverter
May 04, 2012 | Panasonic Televison & Video
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
My Phillips flat screen model 42fd9935/17 has started going black after playing for about 2 hours... you can still hear the sound, but the screen is black... the picture will come back after turning the tv...
The cost of getting this plasma fixed is not costwise compared to getting a new TV. I recommend NOT to get another plasma but get either an LCD or LED for the best quality compared with price. Plasma parts can be quite expensive especially for a 10 year old model or may not be available.
Nov 03, 2011 | Philips 42FD9935/17 42 in. Plasma...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Phillips plasma tv - how to darken dislay while cable radio or music cd is playing?
The only thing you can do is unplug your video out lead from your dvd /cd player while playing it, also check your menu on your sony to see if it has a blank raster setting to activate. Second, why would you want to listen to a cd thru your tv, unless you don't have a stereo or surround sound system to play it on, of which I would definately have anyway. Hope this helps...
Dec 22, 2007 | Philips Magnavox 27MS343S 27" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Philips 32PF9964 32 in. Television Logo
847 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
