Question about Cameras
My olympus vr350 will not turn on and will not charge and it's less than a year old!
When camera is plugged in the orange light illuminates for a few seconds, then makes several "beep" sounds before turning off and nothing is shown on the screen.
    Genius:
  • Cameras Master
  • 1,019 Answers
The beeps are codes that tell the camera tech what service is required.
Posted on Jan 26, 2013
  • shreyasi21
    shreyasi21 Mar 29, 2013
    please elaborate a little more on it
Hey i cant even on my olympus vr-350 when i try to start a display is shown and is again turned off please help asap
Posted on Oct 25, 2013
Ty Price, you're amazing! It worked!!!!!!
Posted on Aug 20, 2013
  • 11967 Answers
SOURCE: My Olympus FE-320 will not focus. When I turn the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 22, 2009
  • 11967 Answers
SOURCE: Our Olympus 7010 has gotten the lens stuck out,
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Oct 16, 2010
Testimonial: "Fix#7 worked. Thanks so much!"
SOURCE: Nikon Coolpix S10 Problem: Lens
You can take pictures ( without VR function ) by starting your camera from play button then switch to photo !
Lens error appear after a shock . VR mechanism have piezo actuators glued with epoxy resin together with an carbon fiber stick . After a shock applied this epoxy broke so no vibration from piezo is transmitted to slider . It is possible to repair ( cheap , only epoxy and izopropilic alcohol needed ) but skills are necessary
(i am not an english speaker so ....)
Posted on Jun 30, 2008
SOURCE: I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: my olympus fe-330 will not turn on
was just having the same problem the camera would not turn on... NOTHING....  battery fully charged was messing around with it opened battery door pushed in on battery while trying to turn on and it came on, guessing battery was not making complete contact added a piece of foil in door to push down on battery when door shut now working fine
Posted on Jul 13, 2009
My olympus camera won't charge properly
If the camera battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Olympus 228230 Model VG-140 Digital...
Olympus VR-340 Won't turn on, lens won't retract.
My camera vr-340, when starts a sound appear and sacreen becomes black . what is this?
Jun 20, 2012 | Olympus Vr-340 16mp Camera Digital Optical...
My camera won't charge, and won't turn on. Should I assume I need a new battery, or is there a problem with my camera?? It's only about 2 years old. Not sure what to spend money on...
If you can't neither charge the battery through USB nor the wall charger, I would advise to first replace the battery. If that does not help, it will be difficult to tell if it's worth repairing or replacing the camera.
Aug 10, 2011 | Olympus SP800UZ Digital Camera
I have an Olympus VG 110/ D 700 and I can record videos with it, but when i upload the videos to my computer its just a huge buzzing noise with loads of distortion. It's a brand new camera and I...
Big buzzing noise sounds like there might be a problem with the camera's microphone. If your camera is less than a year old you should send it to an olympus authorized warranty service center with your sales receipt. As long as it's a defect in the unit they will gladly repair it for you at no charge.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10001
212-673-8400
Jul 01, 2011 | Cameras
My cammera will not charge! The orange light does not show up when charging ???
There are 3 possibilities to charge the battery of the camera:
1. Connecting the Olympus' USB cable to camera and computer.
2. Connecting the wall charger to the camera with Olympus' USB cable.
3. Using a specific separate wall charger for LI-50B batteries.
Be sure to connect the cable well and if the orange LED does not light when trying to charge the battery using above points 1 and 2, there might want to exchange the Olympus' USB cable first to check what's wrong. (Cable model: CB-USB6). Another point is to check if the battery is seated well in the camera.
Jun 05, 2011 | Olympus SP800UZ Digital Camera
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
Cannot be turned on by power button,turns on with view pic button. Lens remain extended. Its just stuck in view pics mode
If these cameras are less than a year old then they are still under warranty, and Olympus repair shops( found on their website) will repair them for free minus shipping charges. The lenses probably have broken gears or have just been pushed out of alignment and can be repaired by someone mechanically inclined and very gentle with components. Can find good used and or possibly new lenses on ebay. Not that hard to replace.
May 23, 2008 | Olympus FE-140 Digital Camera
Lights are on but nobody's home!
I had the same problem two years ago and because the camera was still within warranty coverage, I was able to return it to Olympus for no charge repair and they fixed the zoom lens gear and it works fine.
Oct 14, 2007 | Olympus SP-320 Digital Camera
Cameras Logo
982 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
