Machine wont drain
Door seal leaked,i replaced it but machine will not drain did the leak do damage
  • Washing Mach... Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 17, 2013
  • 3 Answers
SOURCE: whirlpool duet front loadsher leaks at the bottom of door. how do you replace the seal around the door
Hey Guys or Gals
The Whirlpool Duet Washer and why it Leak's. 1) Make sure the Boot(which is the black thing that hook's to your tub and your door) And the ring around it, is tight.Now this Ring,is a Metal Band that keeps the boot on the tub Tight .You can tighten it or loosen it..ifs its loose, then it will leak...Then, there's a Ring around the door as well, Both of these rings are hard to see..so make sure, your really looking good. Now what most people don't thing about is the Main Inlet Tube.On page 18 in the manual.on picture 3.5 it show this source of water that comes into the tub.,this Main Inlet Tube that connect to the Dispenser Assembly,will come loose and will Drip or at times Leak bad,To be able to understand where this is located. First 1) take of the top cover of the washer, 2) take off the front part that hold the door on.That means when you look at your Manual look to pages 31,32,33 and this will tell you how to take off the front of the washer,It's not that hard, to take off,just take your time..and have an extra pair of hands helping you, so it easier and faster.But once you get the front of the waster off,and yes that counts the Electronic display header,That's that button you push to run the washer,,it will pop off after you take a couple of screws out ,after you take the top of the was off..you see them. but back to the MAIN TUBE INLET, this will loosen and water will leak from this now when you replace the boot on this the tube will come loose when trying to put your ring around the boot,you cant tell that its loose becaue you cant see if after installing the boot,i know this dont make any since,but im sure it will if your start to tear it apart..and taking these steps to fix the leak. just make sure that you track the leak,to make sure that this is it...just make sure you take the steps to repair it ..if that means order a new piece then do it. But These Step Will Save you Lots of Time & Money if your Going to play someone to fix it...Here's the Link to the Manual,Just download it and go to the pages i put down ..Might have to copy and paste the address
.http://appliancejunk.com/forums/index.php?action=tpmod;dl=item43
Posted on Jan 14, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
  • 249 Answers
SOURCE: Whirlpool 1A-1B Washing Machine door leak
solution fit new door seal,its leaking where door seal meets glass
Posted on Jun 20, 2008
Lumpy816
  • 246 Answers
SOURCE: I have a Maytag Neptune
For replacing the nuptune boots, I belive these are all of the steps. First, take the 2 phillips screws out of the door hinges. You should be able to lift slightly on the door and pull it towards you to remove it. Also remove the 2 phillips screws straight across from them. This will let your front panel come of (grasp up top and twist slightly to get it off the clips. Lower the front down and you can remove it from the washer and set it aside. Remove the 4 phillips screws from your soap/ fab softner dispenser. Next, remove the 2 5/16 screws that hold the top on to the front of the washer.
To remove the boot, first, pull the front part of the boot towards you. It will actually pull off without much effort. On the bottom (depending on model) there will be a tube at the bottom of the boot that is either stoppered up or connected to a black hose. Squeeze the green clamp to remove the hose if it does have one. To take of the back half of the boot, we're back up top. Lift the top of the machine (you may want someone to hold it or just slide the machine far enough forward the top can stand up by itself). You will see a large spring connected to what looks like a piece of cable coated in clear plastic. Pull the cable towards the front by the spring. It will quickly contract.
Reinstalation time. Take your new boot and install the back half. As you work the boot on, you will see some triangles all the way around to help you line it up correctly. Once it is on, it's time to re-clamp. This is the tough part. Typically what I do, is I make sure the cable is wrapped around the boot from the bottom with the clips at the top. (there is a nice notch for it to fit into) Next I take one side of the spring and attach it to the clip on the cable making sure that the hook side of the spring points up. Now, grab the clip on the cable (without the spring attached) with a pair pf pliers. I use a pair of needle nose pliers to grasp the spring. Now I stretch the two of them together. This will not be easy and the spring will be under some tension. Once the spring is on the clip, lower the lid. (there will be a black wire harness on the right hand side that needs to be tucked back into place for the lid to close properly. Screw the lid down. Re-connect the hose at the bottom of the boot if your machine was equiped with one. Push the front part of your boot back on. Put your door back on the clips where it sits. Lift slightly on the door and swing it closed. Run a test cycle (fill, tumble and drain) while you are standing there to check for leaks. Once you have verified there are no leaks, replace the front panel and your screws. If you run into troubles, message me back.
Posted on Jul 04, 2008
jason0110
  • 66 Answers
SOURCE: How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
Posted on Sep 21, 2008
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Water Leak?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 08, 2013 | Washing Machines
DOOR LEAK
Feb 27, 2013 | Washing Machines
Beko washer is leaking water from underneath
This video will show you in detail how to replace the door seal gasket and fit the new one properly to a Beko washer that is leaking water from underneath washing machine How to Replace Beko washing Machine Door Seal
Jan 24, 2013 | Washing Machines
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
Washer is dripping water at the front when filling and washing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution.It is possible that water can leak if there is gaps on the front door gaskets and must be checked for damaged gaskets which can give poor sealing of the door. So in this case the leak will happen more during the cycle and not on the drain cycle end.
check this video to see how to replace the door gaskets.
http://www.espares.co.uk/advice/washing-machines/a/7/1397/how-to-replace-the-door-seal-on-a-washing-mac.html
Jul 30, 2011 | Kenmore Washing Machines
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Water leaking form bottom of door while draining water from tub
Check that the rubber door seal isn't damaged. The smallest tear or split will let water out. A damaged door seal needs to be replaced with a new one. I assume the water level is normal because excessive water depth can do the same thing...A new door seal is not a big job for a tech......Nomess
Apr 03, 2010 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
