Question about Sharp 70" Quattron LED Smart 3D TV - LC70LE847U
Sharp 70 lc70le847u . When turning tv on unable to change channels and remote will not work. Must turn tv on and off several times for tv to operate. After that digitals channels are non exitant. Must run through channels search and then tv works fine. It takes 20 minites to get the tv working everytime I turn it on. Help.
    Top Expert:
  • Sharp Master
  • 74,383 Answers
It sounds that the main system control memory IC has damaged. Do a reset to this set and check. Refer its user manual to know how to make it a hard reset.
Posted on Jan 17, 2013
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
MrScary66613
  • 1990 Answers
SOURCE: my sharp tv model 20H-S60 remote input button is not functioning.
Welcome to Fixya! First thing would be to Disassemble the Remote and Clean the Pads and Terminals. Inspect the Board for Breaks in the Circuits. These can be fixed Easily with Solder or Even the Contact Pen that Radio Shack Sells. You can Draw the Circuit Back on the Board with it.
Posted on Jan 10, 2009
satavlad
  • 405 Answers
SOURCE: no input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Posted on Dec 29, 2009
bldaz
  • 45 Answers
SOURCE: Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
Posted on Feb 09, 2010
fosg2000
  • 229 Answers
SOURCE: sharp aquos has sound but no picture
you may have a bad signal board, .you can get on ebay, but check your exact model first
check here after get your part #
http://shop.ebay.com/i.html?_nkw=+LC-42D62U&_sacat=0&_trksid=p3286.m270.l1313&_odkw=LN-S4695D&_osacat=0&bkBtn=
Fosg2000, please rate me
Posted on Apr 26, 2010
Dish remote wont change channels
make shure it is turned on the sat setting
Oct 05, 2009 | DISH Network IR Remote Control
I tried to program my remote control to power my sharp tv and it will now turn the tv on and off but I cannot get any directv channels and the screen is fuzzy.
PUT THE DIRECTV REMOTE BACK INTO THE TV MODE TURN THE TV TO CHANNEL 4 OR 4 THEN PUT REMOTE ON DIRECTV TO CHANGE CHANNEL ENJOY
Aug 24, 2009 | Directv RC-64 Remote Control
When my sharp lc 32sb220u is turned on, my direct tv remote will not change channels. this just started. Nothig was changed. after this, i did change the direct tv box and it still would not change...
That remote has to work / it is a direct tv issue since it is their equipment that you are renting and it is supposed to work with your set..
Did you make sure that the batteries in the remote are good? that the remote unit itself is good ( Use digital camera or am radio to test out - see google)
Sep 20, 2017 | Sharp Televison & Video
Infrared Remote codes
try to go threw all codes when you turn on and off the tv after each code and try to change channel after each code then the one that changes the code is the correct code!!! this might help.
Mar 25, 2009 | One For All URC-3021 Remote Control
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
Polaroid Model TDA-03211C
Our tv sharp aquos LC 52 GD^U 52 in. HDTV LCD plays a narrative along with the closed captioning on selected channels, especially channel 2. We cannot get it to turn off and it is annoying to the point of wanting to return the tv. Please help.
Jul 14, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Sharp 70" Quattron LED Smart 3D TV - LC70LE847U Logo
174 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
