Question about Gateway NV5378u Notebook
My Gateway nv5378u Laptop Fan makes a horrible noise when turning on.
Every time I boot up my laptop the fan sounds like it is rubbing ot out of balance. Can I turn the fan off in the Bios or elsewhere in the computer and just use an external cooling pad? If I can turn off the fan where specifically can I turn it off? I've watched: 1)How to disassemble a Gateway NV52, NV53 http://youtu.be/ab0tt7LflHw 2)Gateway NV Laptop Repair Fix Dis-assembly Tutorial http://youtu.be/f65ohS_EfdI Both videos get pretty complicated and I'm unsure if I have the knowledge or ability to take it apart myself. A repair place here in town is too costly for my budget and beside I bought it refurbished about two years ago.
    Problem Solver:
  • 15 Answers
Fan is hit something or worn out take it and have it replace before you burn the processor up .good luck
Posted on Jan 16, 2013
  • Catherine Jan 16, 2013
    Like I stated in the question and info I donot have the extra cash to pay a repair place as most of them here in Southern California want $50 just to look at the computer! I am on disability and only live on around $630.00 a month.
4 Suggested Answers
  • 70 Answers
SOURCE: gateway m255 laptop cpu fan wont let me boot up
open your laptop up and make sure the fan cabels are in correctly if not push them in if that dosen't work get a new fan for it
Posted on Jun 15, 2012
onyeobike
  • 70 Answers
SOURCE: gateway boot problem
This mostly happens when your motherboard is bad or one of the memory modules is bad.
The led light comming on indicates your power pack is ok but a component is failing to start especially when the laptop stops at the first screen stage where the manufacturer names appears.
The steps needed to solve this kind of problem would require technical skills and physical inspection.
If you still have a waranty period then seek a free service repair from an authorized or certified gateway service centre at the nearest centre closest to you.
If your warranty has expired, i still advise taking your Laptop to the closest Gateway service centre.
Posted on May 21, 2009
Murphybanton
  • 2004 Answers
SOURCE: gateway MT 3422 problem
There has been a lot of problems/ complaints about this particular product. That is why I always recommend HP notebooks.
You can take it to a service centre where they deal in Gateway products but I bet you might need to replace your motherboard.
Good luck.
Gateway NE56R31u will not boot after memory upgrade
sounds like you have either a bad module or it is not the right kind , if you have ddr2 memory stick and you have added a ddr3 it will not work or you have exceeded you systems memory capability it will not work .
Jun 15, 2014 | Gateway NV5378u Notebook
My fan was making a sound like it was loose but when i went in it didnt feel loose at all. it makes a sound now like when it kicks in it is hitting something. Im not sure what is going. thought it was...
Sounds like a bad fan bearing over the processor. Your Gateway is actually made by ACER. They are a very good brand, but are known for fan problems in their laptops. Here is a video of how to properly disassemble your laptop: http://youtu.be/CKVljMrPmCE. Just be sure to wear an anti-static wristband or static from your hands can short-circuit your motherboard. Also, if the fan stops working completely before you get it fixed, turn it off ASAP or your PC will burn up. You can find a replacement fan here: https://www.google.com/search?q=Gateway+NE56R10u&rlz=1C1PRFB_enUS510US510&oq=Gateway+NE56R10u&aqs=chrome..69i57.33076900j0j7&sourceid=chrome&espv=210&es_sm=122&ie=UTF-8#q=Gateway+NE56R10u+fan+problems&safe=off&tbm=shop. Good luck.
Feb 12, 2014 | Gateway NE56R10u Laptop
When I turn the oven on, there is a fan that comes on that sounds very noisy. It sounds like a vibration in the cooling fan. I'm wondering if simply swapping out the blower would take care of the noise? ...
yes this will work for you, but before you change out the fan motor make certain the fan blades are unobstructed and not rubbing against anything this can make quite a horrible noise as well.
best regards Falco
Nov 04, 2013 | KitchenAid KGRS807SSS Gas Kitchen Range
Gateway m255 laptop cpu fan wont let me boot up
Jun 15, 2012 | Gateway M255-E Notebook
I'm user gateway nv48 but my problem now my laptop always auto shut down when i play games. if surf internet it not happen like that.if i put my laptop in my hand and put it not flat , my fan laptop create...
Your computer is shutting down due to overheating. Since the fan is making noise it is not working or cooling correctly either because it has lint or debris interfearing with the fan blades, ot the fan bearing is going out. To determine this you need to access the fan and clear it of any blockage. You will need to remove the keyboard to access it. Not all Gateway models are the same but once under the keyboard you should be able to work with it. CLICK HERE for keyboard removal instructions. If you find lint or dust blocking the fan exhaust at the heatsink and can clear that out your laptop will run much cooler and should solve your problem. If the trouble is with the fan itself you can still find a replacement and be able to swap it out.
(if the removal of the fan requires removal of the heatsink assembly you will also need to apply new thermal compound between the CPU and heatsink after cleaning the old compound off with rubbing alcohol.)
Apr 25, 2011 | Gateway Computers & Internet
I have a gateway NV55C03u, The fan isn't turning on or is running slowly when ever i go to play World of Warcraft (WoW). I have never had this problem running WoW before, and i would like to know if buying...
does the fan run normally when doing other things?
Does the fan make any unusual noises?
Is it dirty, or coated with dust?
Sometimes cleaning and oiling will keep you working for some time.
Dec 26, 2010 | Gateway NV55C03u Laptop
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
Loud fan belt type noise from laptop
There are no belts in a computer, sounds like something is rubbing in your computer cooling fan blades, get a can of Duster ( to clean dust from things) and spray the compressed air into all the vent holes to clean out any dust and debris.
May 23, 2010 | Sony VAIO PCG-K35 Notebook
HORRIBLE NOISE!!
call tech or installer and check condensor fan assuming noise is outside. shut down outdoor unit and hand spin the fan blade to see if it is rubbing
Aug 09, 2009 | Goodman CKL24AR24 Air Conditioner
Dell Inspiron 1200 Fan Making a Noise
Sounds like the fan sucked in some debris.Try looking in with a flashlight.Be sure to unplug the laptop before you try to remove anything you might find.
Mar 24, 2009 | Dell Inspiron 1200 Notebook
Gateway NV5378u Notebook Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
