Compatibility issues between a cable modem and an Apple Airport Express.
This is a response to an AirPort Express issue.
Posted on Jan 16, 2013
SOURCE: ISP problem with 2wire 2700HG-B
When I purchased the same router on Amazon I did my best to set it up on my own, but you need the correct IP information you can only get from your customer support at AT&T. I'm using this router with an old Airport card in an 2003 iBook and a 2007 iMac (built in Airport express card). The set-up was all done wirelessly, with bellsouth (AT&T) customer service instructing me over the phone, the process took about 15 minutes.
My suggestion is to call AT&T and speak with someone who knows what their doing, and they do use the SBC global page to set up the unit, starting with http://192.168.1.254/ for the system summary, from there you can set up your password etc...
Posted on May 24, 2008
marked
  • 6487 Answers
SOURCE: DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Posted on Nov 10, 2008
  • 8 Answers
SOURCE: New iMac very very slow loading pages with Actiontec GT704-WG
I have seen this before and this has cured it:
Check the DNS settings in the Network panel and enter a manual DNS that matches the base address of the router (192.168.0.1 for this router).
System Preferences > Network > Ethernet > Advanced > DNS. Click the + sign and add 192.168.0.1. Click OK, and click Apply on the next screen.
macs2u
Posted on Aug 12, 2009
  • 112 Answers
SOURCE: Linksys router and airport express don't play my remote stereo
You may need to install the driver.
http://www.apple.com/airportexpress/
  • 1121 Answers
SOURCE: ON APPLE SYSTEMS... JUST GOT 2WIRE2701 WIRELESS
so apple is always apple, no escape
Posted on Mar 16, 2010
I have a RCA Digital Broadband DHG535-2 modem but my Apple Airport Extreme router does not work, any ideas on how to resolve this issue?
Apple uses airport for its wireless connection, how ever the device where you want to connect to should have the wireless feature embeded to it or you should have a wireless router to distribute the wireless signal, if you are using just a modem which doesn't have capability of distributing wireless signals, the Apple airport will surely not work for it requires a modem to connect to. you need to get a router and connect it in your modem so the Apple will work for wireless as well.
Dec 29, 2011 | Computers & Internet
Just got a new router (motorola) and airport will
Check your connections:
DSL-modem to telephone-jack (or cable-modem to cable-jack).
Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
Ethernet cable from LAN port on router to WAN port on your Airport.
Cut the power to the Airport, and then plug it back in, so that it restarts.
Apr 17, 2010 | Apple AirPort Extreme Router
Airport utility cannot find airport express - ask for rescan
connect a ethernet cable to it. find it in the utility and reset it.
Jun 07, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Can't connect to the internet with my Airport Express
Make sure your network settings are set to DHCP manually and that you are getting an IP address that does NOT start with 169.258
If you are using a Windows PC you may have to use the ipconfig /release and ipconfig /renew to refresh your DHCP settings.
Also try using the Airport utility (located in the Utilities folder) if you have a Mac. It will tell you if there is an issue.
Dec 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple Airport Express not working
You need to use the AirPort utility, which will walk through the setup and configuration of it. You were already on the right track to get it going. If it mentions there is an update available for it, though, do the update first.
Jul 28, 2008 | Apple AirPort Express with AirTunes...
Using to Print Wirelessly
mac or windows? Here's the airport express firmware update which resolves a lot of known issue regarding the express.
windows:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63forwindows.html
mac:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63formacosx.html
May 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Vista compatibility
Vista has very little drivers for equipment sad but true. However in your case you can use Airport Extream. However here is what an apple tech had to say: If you are a Vista user and you don't have access to a Mac, you will not be able to get this working. Apple hasn't yet stirred itself to release a version of Airport Express Assistant that works with Windows Vista - you can't set it up via Windows' own networking software and nor does the Airport Admin Utility work under Vista. It installs and you can run it, but it returns error messages if you try and connect to the Airport Express. I had to use a Mac to get it working, though once it's set up as a client to your existing wireless network, you can stream from iTunes on a Vista PC to the Airport Express. The documentation is very poor, too, with this: I had to do extensive Googling first to track down the fact that I couldn't set it up with Vista and second to identify the device's IP address and default password. Having said that, it is a breeze to set up via a Mac and works like a dream witih Vista once it's up and running. But don't bother if you have Vista until Apple updates the software. Was this review helpful to you?
Aug 23, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
