Question about Honda Garden
Honda gx31 timing putting new piston on ,how to put cam the right way
  • 41 Answers
SOURCE: 2004 KAWASAKI KXF250
try a new plug sometimes a plug will not fire under compression. also adj the valves
Posted on Nov 25, 2008
emissionwiz
  • 76691 Answers
SOURCE: hi ive got a daewoo
Required tools: 13mm open end wrench 10mm shallow and deep socket 8mm socket long flathead screwdriver 17mm deep socket T50 torx socket 1/4", 3/8ths and 1/2" ratchets and extensions E10 inverted torx sockets 6mm allen wrench 15mm open end wrench 7mm socket 12mm open end wrench 14mm socket 12mm socket 8mm, 9mm and 10mm allen head sockets 19mm socket prybar needle nose pliers If you are doing this because your timing belt broke you will also need to buy a complete cylinder head, head gasket set, and both idler pullys. ALL DAEWOO MODELS WILL BREAK THE INTAKE AND EXHAUST VALVES WHEN THE TIMING BELT BREAKS. Start by removing the air cleaner assembly from the throttle body, remove the air filter and housing jack up the vehicle and remove the wheel, remove the plastic shielding in front of the accessory drive belt assembly, remove the accessory drive belt, place a jack with a block of wood on top underneath the engine oil pan remove the front engine mount, remove the crank shaft pully ( the 4 allen head bolts only not the 17mm bolt in the center.) remove the metal plate behind the engine mount bracket on the engine, remove the plastic timing belt cover 3 clips on top 2 10mm bolts on bottom. Rotate the engine until the #1 cyl. is at Top Dead Center on the compression stroke or line up the crankshaft timing mark with the mark on the inner timing belt cover ( notch in cover with notch in pully) on the camshaft pullys -- ( intake cam line up the line on the pully with the line on the inner cover)( exhaust cam line up the arrow on the pully with the arrow on the inner cover) loosen the 13mm bolt in the belt tensioner and using the allen wrench rotate the tab until there is slack in the belt. Remove the belt. At this time I would reccomend you replace the water pump, both plastic idler pullys as they tend to overheat and lockup, and the belt tensioner. Make sure all your marks are lined up, you may need a helper to hold the Exhause Cam in place as it tends to move during belt installation. Put the timing belt underneath the crankshaft pully, install the belt leaving the intake cam for last and NO BELT SLACK on the right side between the crank and the exhaust cam. Once the belt is installed rotate the crankshaft over 2 revolutions and make sure is rotates freely, and your timing marks are aligned perfectly if not the engine will not run properly, tension the belt as needed. Installation is the same as removal. To clarify, on the DOHC engine, the intake cam gear has a line on it, and the exhaust cam gear has an arrow on it. These should be lined up with the corresponsing line and arrow on the VALVE COVER, pointing straight up. I just went through this process over the weekend, and spent quite a bit of time looking for these marking as I had removed the valve cover. Once I found them, it was plain and simple. In addition, be sure to not over tighten the belt when reinstalling. The tensioner has markings on it for "old" and "new". DO NOT adjust past "new", as the car will sound like a jet engine, and the belt will not last for very long. One more item that you may as well replace while you are in there is the cam position sensor if you have not already, as there have been issues with them, and the timing housing has to be opened to get to it
ginocussen
  • 216 Answers
SOURCE: How to set timming on a 2003 Honda XR80 dirt bike?
This is the closest manual to your bike I can find.
http://www.autorepairmanuals.biz/site/57...
As you can see, it covers from 1979 - 2003 - Honda rarely change their engine configurations when they make something that works.
This manual was probably last printed in 2003 - and later year bikes just added updated pages (Honda does that quite often to save on re-printing new manuals).
The XL model is exactly the same as the XR, except the XL has additional components to make it street legal - battery, head light, tail light, turn signals, horn and street legal tires
Posted on Mar 21, 2009
  • 166 Answers
SOURCE: the timing belt broke on our 95 elantra and im fixing it how cam
you need to get a diagrm . try googel . timming marks for your car . if the belt broke while driving more then likley there is engine damage
Posted on Jun 04, 2009
  • 176 Answers
SOURCE: how to put the belt right on honda crv 99
Your local Napa store can print you out a routing diagram, but first check around under your hood, most cars have a routing sticker.
Posted on Dec 19, 2009
2004 honda accord ex 2.4L, how do I set cams before putting on timing chain?
Not with the valve rockers in position. If you do then the valves will bend as they hit the pistons
Mar 14, 2015 | 2004 Honda Accord 2.4 EX
I have a 2000 xr 80,we put new piston and rings in.Timing marks were lined up but is there a way to fine tune timing?
The valve timing is a static setting. As a rule it will either work or not. The only adjustment is usually the ignition timing.
May 02, 2011 | 2000 Honda XR 250 R
My car wont start but it will turn over. i thought it was the starter i replaced that. mabey you can suggest another solution thank you
You should check the cambelt timing.Take plug no 1 out. Put your forefinger over the plug hole. Turn the engine until you feel the compression coming out of the hole. Turn the engine slowly with your hand until the piston is in the top position. Use a long screwdriver in the plug hole todetermine that the piston is at the top position. Remove the tappit cover. The camshaft should then be in the position where the inlet and outlet valves on piston no 4 wants to open and close when you turn the camshaft. If that is the position, your cambelt timing is correct, If not, Remove the belt off the cam pulley, turn the cam so that on piston no 4 the cam wants to open and close both the inlet and the outlet valves . When you turn it to the left, the one valve wants to open and when you turn it to the right the other wants to open. Put the cam exactly in the centre and replace your cam belt but make sur that your piston no 1 sta at the top. Your cam timing should now be 100% and your car should start if it gets petrol.
Jan 19, 2011 | 1989 Honda Accord 4 Door
Hello iv changed the piston on my kids honda xr 50 now it wont kick over i can move the piston through the head pulling the small chain in the cylinder head about 2 turns of the coge the opposite way to...
It sounds like you have not set the cam chain timing. If the cam is not timed to the piston position, the piston can come up and hit an open valve. If you put the engine together and kicked it over so the kick jammed then the piston has hit an open valve and chances are very strong that the valve is now bent. Bummer... If bent badly enough the valve guide may be cracked as well. Double bummer... I would pull the head off and do a visual inspection of the valves. Do they LOOK fully closed? Can you see a strike mark on the top of the piston? If all looks good, I would put the head back on then set the cam timing then turn the flywheel over by hand a full four revolutions. If it doesnt bind up you should gently push the kick lever to turn the engine over a few times. Okay, the piston doesn't seem to be hittinng a valve. Now do a compression check. You want to have 130 to 160 psi. If you do, the valves are okay. Get back to me by posting a comment if you don't know how to set the cam timing. The following diagram may be self explanitory. Please rate my answer. Thanks.
Feb 21, 2010 | 2002 Honda XR 200
I have a 300 honda fourtrax how do u put it in time
ther are some plastic plugs on the left side case cover, the timing is set with the piston at TDC, Top Dead Center, the piston is at the top of the compression stroke and the cam lobes point up, this is also a good time to check valve clerance. to set timing rotate the motor slowlly untill a notch is visible in the window of the small offcenter side plug or maybe marked T but not F. the cam gear also has a mark that corisponds to a notch,
Jan 01, 2010 | 2002 Honda XR 200
How to change the timing chain?
By rights you should pull the sidecase off the motor & the rocker cover, & fit an endless chain over the crankshaft to the cam(s)if you can get a chain with a joining link or get one from a bike shop & ask them to split it for you, you can just take the top cover off the motor, line the cam timing up (piston @ top dead centre(should have timing mark), cam lobes (pointy part) facing as far as you can get both at the same time from the cams, remove timing chain tensioner, let old chain go slack, join new one to it & loosely pull through, make sure bike is upright when you put new one in so chain locates on bottom sprocket properly, then reassemble chain & peen pins over with ball peen hammers.
Dec 24, 2009 | 2005 Honda CBR 125 R
Timing chain 110 hymoto pit bike
Put the piston at TDC (Top Dead Center) by lining up the timing marks on the flywheel and stator. Put the cylinder head back together with the cam installed so the high points of the cam lobes are pointing kind of downward. Pull the cam chain taught on the front side of the engine. Put the chain on the cam gear such that, when bolted to the cam, the index mark or marks are in the proper position.
The proper position depends on what markings are on the cam. Some bikes have a single mark; an arrow, a straight line or an "O". The mark should line up with the center-line of the crankshaft. If the cam has two marks opposite each other, the lines should be parallel with the gasket surface. You will need to rotate the unbolted cam left or right just a bit in order to match up the bolt holes to the gear holes.
Can I get a “very helpful” rating on this answer?
Aug 19, 2009 | 1984 Honda GL 1200 Gold Wing
Timing 06 70crf cam
just put the piston at the top then if singel cam motor put the cam lobes facing down there should be a line or dot on the cam sprocket which must line up with the head
Aug 11, 2009 | 2005 Honda CRF 100 F
Still need advice
Turn crank so that timing mark on front pulley is at 0 degrees.
Remove the timing cover and you should see a mark for the cam to line up with.
You want the cam lobes on No.1 cylinder to be pointing away from the followers wether they be rockers above cam or buckets below. This will be the compression stroke.
Once the cam timing is set you can recheck the distributor. It should point to No.1.
Jan 03, 2009 | 1989 Honda CRX
Garden Logo
306 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
