Question about Dimplex Heating & Cooling
Dimplex DS3311 switch is overheating and melting. What to do?
I have ordered replacement switches from Dimplex and installed them. My unit/switches keep burning out... What I think is occurring is that the switches are getting hot and melting. In particular, it is the middle switch which is designated as the Low Heat switch. The diagram shows the Red wire going into postion 1 Red wire postion 2 and the actual wire connecting to position 2 on switch is ??daisy chained?? connecting Grey wire... Anyone have any suggestions? Other than Electrician... I hate to throw it out....
    New Friend:
  • 72 Answers
How long does it take before the switch melts?
You could try retrofitting a switch from the hardware store that has a higher watt/amp rating...
Posted on Jan 17, 2013
  • swinkler740 Jan 17, 2013
    Thanks for responding. switches melt after about 4/5 uses approx 8-10 hours of use
  • Tech X Direct
    Tech X Direct Jan 18, 2013
    I would contact Dimplex"s free tech support and describe the problem in full. Make sure to communicate how often they are burning out. Technical specialists: 1-888-346-7539 Monday - Friday 8:00 a.m. - 4:30 p.m. EST
SOURCE: Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Posted on Jan 21, 2009
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
  • 24 Answers
SOURCE: Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Posted on Apr 15, 2009
SOURCE: open circuit on electric heater
Well, it's a little late but since this is still up and people still read it apparently, here's a few more pointers on problems like this.
The part that blew is usually called a thermal fuse, and appliance parts stores usually insist on knowing the temperature that is printed on the side in order to get you a replacement.
They should also be able to sell you heat-resistant crimp-on connectors with which to install it.
Small motors usually slow down and stop because the bearings are plugged up with dust and crud. A drop or two of light oil might work but more likely you'll have to disassemble the motor. Don't use WD-40 unless you like your house full of that smell, and if you do chase it with some real oil because it evaporates out of the bearings and leaves them dry eventually. Be careful not to bend the fan blades. Clean the bearings and the shaft until a white piece of cloth doesn't show any dirt.
For those of you with heaters still running, an ounce of prevention: Take care of the motor as soon as you notice it running slow. The slower it runs the hotter the coils get and if they get hot enough the thermal fuse blows and you have to hassle with replacing it. Also, nichrome wire eventually fails by breaking, stretching, and/or sagging; and the hotter it gets the sooner it fails.
Posted on Dec 30, 2009
My heater motor stoped turning and blowing but the heat strip kept heating and melted the rotating fan . It is a 20406D7F 077 can I order a whole complete replacement unit
Yes, you probably can. Plus, Dimplex should be made aware of this. Contact Dimplex Technical Service 888-346-7539, Monday -Friday, 8a -4:30p ET. Have the model number, serial number and proof of purchase, handy when you call.
Hope this helps you get the parts you need.
Apr 26, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have a dimplex springbourne fire and the heater shuts off after it has been on for a short time what is the problem with the unit
Apparently, the heater is overheating and the overload switch is shutting the heater element off.
Contact Dimplex USA Technical Service at 888-346-7539 for assistance in solving this problem.
Mar 07, 2011 | Heating & Cooling
We need to order a DS3311 replacement switch for our fireplace
You can purchase the part directly from Dimplex USA, by calling
800-668-6663 Monday - Friday 8:00 a.m. - 4:30 p.m. EST
Mar 02, 2011 | Dimplex Compact Electric Flame Stove...
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
My dimplex has a remote control box that plugs into the outlet. I haven't used it for a year or more. smelled something hot when it was on. the outlet & box was very hot, the bottom of the box was...
You definitely have an electrical problem either with the remote box or the the A/C unit itself. Something within either of the aforementioned is overheating and use of the air conditioner should be stopped immediately, as it is a fire risk. Unplug everything from the wall outlet and contact a service company that services Dimplex Air Conditioners. This is not a DIY fix!
Feb 07, 2011 | Heating & Cooling
Why does my dimplex model bf8000st fan and heat turn off after 2 or 3 minutes? the flame lights keep working, just no fan or heat.
"Resetting the Temperature Cutoff Switch
This unit is equipped with a thermostat which controls the temperature
of the room by turning the heater on and off. The heater is protected
with a safety device to prevent overheating. Should the heater
overheat, an automatic cut out will turn the heater off and it will not
come back on without being reset. It can be reset by switching the
Main On/Off Switch to off and waiting five (5) minutes before switching
the unit back on."
http://dimplex.com/cms/publications/7208680300r03_EN.pdf
Dec 13, 2010 | Heating & Cooling
Fire place insert light replacementht
Dimplex has discontinued use of the remotecontrol unit you have requested; therefore we are no longer able to providethis as a replacement part. In order to operate your unit please plugyour power cord directly into your wall outlet and operate the stove via themanual switches.
Aug 20, 2009 | Dimplex Compact Electric Flame Stove...
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex DS5804 remote unit
Call Dimplex : 1-800-668-6663 ext# 358 They will be gla to help and send parts if needed.
Dec 09, 2008 | Dimplex Compact Electric Flame Stove...
The switch broke on my model DS3311 and while taking it apart, it broke the one of the other switches. I need two switchs and the wiring diagram for this model
Either go to: www.dimplex.com or call their number: 1-800-668-6663 ext : 358 They are very helpful!
They can help you with a reapir manual you can download as well!
Nov 19, 2008 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
172 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
