Question about Whirlpool AWM6100 Front Load Washer
Awm 7100 will not drain
Not pumping, no power going to pump
  • Whirlpool Master
  • 17,130 Answers
If there is no power going to the pump then the fault seems that the program controller is not switching . This means that the program controller is the suspect. Try and clean the connectors and contacts to confirm the case.
Posted on Jan 17, 2013
4 Suggested Answers
kakee
  • 1269 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
That's a timer problem. Check on the user's manual on how to reset the timer settings. The timer can be replace if found defective but you need a pro technician to do it.
Posted on Aug 29, 2008
beltronic205
  • 1466 Answers
SOURCE: Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Posted on Mar 31, 2010
Daniel S
  • 4323 Answers
SOURCE: AWM 5145/5 starting program then
Hi
As the water inlet valve is already replaced and everything else works fine the issue seems to be with the pressure switch located inside the control panel that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 23, 2011
Whirlpool awm 9000 I bought a used Whirlpool
The error code F/H for this machine means that the drain pump is blocked. Look at your manual for how to access the drain pump and clean it out. This will resolve your issue.
Oct 18, 2013 | Washing Machines
Whirlpool washing machine AWM 5100 has stopped going thru the full cycle.
My machine did a similar thing and in my case, it was debris in the filter. It took several clear-outs before the object appeared.
Mar 21, 2012 | Washing Machines
Hi my wirlpool awm 5100 washing machine front loader is not draining when it goes to the draining part it makes the drain noise but there is only very little water getting drained. I think the drain filter...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Aug 02, 2011 | Washing Machines
Whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a AWM 500 washer and it says E4 i have lost the manual for it i think its the drain pump and want to know if u can get a replacement part
Most F/l wahers have a pump MOTOR which can be replaced with a generic. The motor can be removed from the pump body and replaced. Check with a laundry equipment outlet. Use a marker to show alignment before disassembly. Check that the pump filter is not blocked first..Good luck...Nomess
Apr 22, 2010 | Washing Machines
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool AWM6100 Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
