Question about Zanussi ZWF1430W Front Load Washer
FAN BELT THE FAN BELT HAS FALLEN OFF MY ZANUSSI AQUASPIN 1200 HOW DO I GET IT BACK ON. THE MAHINE ONLY OPENS AT THE TOP
  • Zanussi Master
  • 3,463 Answers
It can be done from the top, but it is awkward.
Remove top cover, and tilt washer towards you , you may need someone to hold it steady for you.
Reach down inside washer and slip belt over motor pulley, then start to feed belt over drum pulley guiding it round the pulley, at the same time turn drum with pulley gradually feeding the belt around..
The only other way is to remove the rear half of the cabinet, this is quite an involved job.
Good luck.
Plz rate my soution.
Thanks.
Posted on Jan 24, 2009
Zanussi zwd 1260w won't drain, no apparent blockages
REMOVE POCKET BY TIPPING MAHINE BACKWARDS. I HAVE SEEN ****** STICKS TO TOYS JAMMED IN POCKET.
Jul 26, 2010 | Zanussi ZWD1260W Front Load All-in-One...
Vent fan belt fell off because the housing unscrewed kenmore elite oasis st mod 110.68062801. how do i get it back on? it is obviously tight. and which way should the belt be looped?
Rich, I had the same problem. Popped the top by sliding a putty knife into the space between the front panel and top corners to release the clips, laid it bach and supported it,unscrewed the front two screws, detached the door wires. Removed the cover off of the lint shoot, (glad I did .... yuck) cleaned it out. My pulley had unscrewed from the top of the exhaust fan and the belt had fallen off. I reattached the pulley by using an adjustable wrench and holding the fan blades underneath in the lint shoot. Now you should have the motor/flywheel on the right and the fan pulley on the left. Place the belt over the flywheel and seat it into the pulley groove. With your left hand, hold the bottom belt into the groove on the fan pulley and with your right, push the top of the belt against the top of the pulley and begin to turn the fan pulley clockwise threading the belt into place. Good luck!!
Apr 19, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
The grill element has fallen down because the two
What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
Apr 06, 2010 | Zanussi ZDQ695 Electric Double Oven
The drum for our Zanussi TC7103 has stopped spinning
sounds like a new drive belt is required. pull the machine out remove the mains supply!!!!
remove the top and look into the back of the machineif you cant see the belt them remove the back of the machine, it's like a small fan felt from a car it's either come off or disintegrated in which case you'll need a new one.
Nov 09, 2009 | Dryers
MAIN OVEN FAN STOPPED WORKING
Firstly switch off the stove isolator(switch)
1:I would suggest removing the back panel and checking the wires to the motor to see if any terminals have broken/fallen off(on the Zanussi ovens you should be able to see these easily).Also check that the armature can spin freely.
2:If OK, Switch isolator and stove back on and check for voltage (230v) to these terminals.
3:If No 1&2 solutions have not solved your problem please come back to me.
Hope I have resolved you question, but please leave positive feedback if so , as it still takes time to answer questions and it would just be nice to know if I have helped.
Aug 12, 2009 | Zanussi ZDF490 Electric Double Oven
Belt-washer won't spin
not a fun belt to change on this mahine, thinkin youll need to unmount the motor under the unit to get it on. is it physically broken???
Mar 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Zanussi aquacycle 1200
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
81 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
