Question about Clarity C210 Corded Phone
Need manual to fix call fowarding to reverse to original setting
Transmission
Check transmission fluid level Almost all transmission slip problems originate from not enough fluid
Mar 13, 2014 | 1997 Jaguar XK8
My pride quantum only turns to the left either foward or in reverse?
did you check your freewheel levers sometime they LOOK latched but are not. otherwise yes there could be a loose or dirty connection underneath
Aug 05, 2012 | Pride Jazzy Select 6 Indoor Power...
The tray wont advance in foward or reverse also the remote will not work
Please send an email to LBrown18062@hotmail.com I will send you both the user manual (to troubleshoot the issue) and the Service Manual (to fix the issue). Please put [Kodak CAuser-service] in the subject line and I will send them both to you right away. Lawrence
Oct 26, 2011 | Kodak Carousel 4600 Slide Projector
John deer gator goes foward in the reverse position and reverse in the foward positions.
you just need to switch the polarity on the motors swap the two wires around
Feb 25, 2011 | Peg Perego John Deere Gator HPX
Mazda wont go foward or reverse.
If you are lucky, you are just out of transmission fluid. Add fluid to refill the transmission to the mark on the dip stick. Afterward, you need to determine where the old transmission fluid leaked out and fix the leak. If refilling the transmission does not fix the problem, you then need to look at fixing the transmission. Are you sure the shift linkage is ok?
Jul 31, 2010 | 2006 Mazda 6
1988 wrangler goes foward but not in reverse. It won't engage in reverse. 1st, 3rd, 4th are great 2nd winding sound. what needs to be fixed or replaced?
it sounds like you have 2 bad gears, 2nd gear may be fine for an hour or for ten years, theres no telling on that. your reverse gear is probably shelled out. your best bet is to rebould your transmission or buy a new one, sorry
Nov 06, 2009 | 1988 Jeep Wrangler
Clarity C210 Corded Phone Logo
66 people viewed this question
Top Clarity Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
