Question about Stihl Garden
Stihl MS250-C EasyStart start assembly needs replacement
Part no. 1123 080 2116
  • Stihl Master
  • 1,807 Answers
dontbother10
  • 2220 Answers
SOURCE: removing flywheel and clutch assembly ms 250 stihl
You need a piston stop, watch part of this to explain use:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Make one with starter cord or rope:
I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. HTH
Lou
Posted on Nov 19, 2009
Testimonial: "Thanks for your help, I got the clutch assembly off with the rope as a cylinder stop. But the flywheel is going to require a puller i think."
dontbother10
  • 2220 Answers
SOURCE: stihl 025 /ms250 any difference
Answered in clarification.
Posted on Feb 05, 2010
#1 Taper
  • 1041 Answers
SOURCE: free stihl ms250 digram
Here is the manual you needed:
lawnandgarden.manualsonline.com/manuals/mfg/stihl/ms_230.html
Jim
Posted on Sep 28, 2010
  • 10 Answers
SOURCE: need to know how to take clutch off stihl chain
take the bar cover off, remove the bar and chain. there will be a lock key that u can easily remove with a flat head screwdriver, after u get it off all pices should slide out easily, just rember how to put it back and make sure not to mess up the oiler needle
Posted on Mar 02, 2011
philwalker78
  • 608 Answers
SOURCE: On a Stihl MS250 Chainsaw are both bar hold down studs into the plastic tank if the front one is stripped can it be fixed
Hi, yes and yes. You can buy an oversize stud from a stihl dealer that is designed to fix your problem, regards Phil.
Posted on Sep 02, 2012
Where is the reed valve on stihl ms 250
I don't generally like to work on 2cycles. Reed valves are under the carb on the ones I've seen. I watched this whole video of a 250 being disassembled and I didn't see reed valves. It looks like a ported piston design to me aka no reed valve. I'm willing to be wrong.
Here's a complete tear down video -
Stihl MS250 Chainsaw Teardown
Here is an exploded diagram and I don't see reed valves on it.
Stihl MS 250 Chainsaw MS250 Parts Diagram
Jan 12, 2018 | Stihl Garden
Need parts diagrams for stihl chainsaw MS250 & blower BG85
Request Illustrated Parts Breakdowns (IPBs) directly form Stihl.
Aug 29, 2017 | Stihl Garden
Looking for parts manual
Write brand name and wiring diagram into Google then click images should find it somewhere there if not type in same thing but instead of wiring diagrams type schematics
Apr 15, 2016 | Stihl Ms250 Ms230 Ms210 Chain Brake...
How to replace pullcord on chainsaw
Hello, here is website to help you with replacement.
Pull Cord Repair On Stihl MS250 Chainsaw
Nov 14, 2015 | Stihl Garden
Need repair and service manual for Stihl 012 chain saw engine
google the stihl web site and if there are manuals available ,you will find them there.
May 27, 2015 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Stihl MS250 overheats and burns out engine.
the carb fuel augments mite be set to lean or gas oil mixture not mixed rite
Apr 11, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Stihl MS250 Chain saw overheats. I have had two MS250 saws overheat and be ruined. I have always been careful with the fuel mixture. I have kept the saws clean. The saws were not old. In fact, I had...
Do you clean the entire saw inside and out sometimes when you keep it in a close room for months or days even they could overheat. Don't start right away but wait till its fuel is really mixed in properly. Get it checked by a service center.
No oil to chain stihl ms250
Oil pumper oil gear, needs to be adjusted or replaced. Check out a video how to replace.
Nov 29, 2013 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Stihl power pruner serial number
The serial numbers on the FS130, HL90K,HT101 and BG55 would be on stickers if they are still there... The MS250 serial numbers are located on a 'flat' by the side of the exhaust and sprocket cover. (depending on the year of manafacture)
Jun 27, 2013 | Stihl Garden
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
193 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
