Question about Lennox Heating & Cooling
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
The manual says this is a normal defrost operation, but the system has been down for almost 3 hours. How do we reset? Is further action needed?
  • cresbwells
    cresbwells Jan 16, 2013
    Should have said this is a mini split system. ZO, not z0.
  • 40 Answers
H1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Posted on Jul 05, 2014
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Jun 20, 2016 | Frigidaire Refrigerators
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Lennox MS8 heat mode never shuts off
Is it the blower that doesn't shut off or the heating unit?
Nov 08, 2014 | Heating & Cooling
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
On the refer side we are getting a temp. reading of 67 degrees at the top as you go down it gets cooler to were in the crispers it is 33 degrees, have changed the thermistor and the evap fan motor what...
It could be a problem with the air damper but.... I doubt it.
Down load this manual and go to page 29 of the pdf file,
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
You will see this:
Self-Diagnostics in the normal operation
2-1) To select this function, press Power Freeze and Power Cool buttons simultaneously for 8 seconds with an audible
tone.
2-2) In the self diagnostic mode, only corresponding LED segments will be illuminated (see the check list on the next
page)
2-3) After a 30 second illumination of error signal, the system will return to the normal operation.
Note the position of the LED in the temp windows and the side that it appears on. Then see the Control panel LED legend along with the corresponding position legend listed below listed on page 30 for interpetation. This should tell you what has failed.
Make sure to read the Details of each failure on page 30 also.
This is the legend.
NO Error
01 ICE MAKER SENSOR
02 REFRIGERATOR SENSOR
03 REFRIGERATOR DEFROST SENSOR
04 REFRIGERATOR FAN ERROR
05 ICE MAKER function error
06 CoolSelect ZoneTM SENSOR
07 REFRIGERATOR DEFROST ERROR
08 EXIT-SENSOR
09 FREEZER SENSOR
10 FREEZER DEFROST ERROR
11 FREEZER FAN ERROR
12 CONDENSER FAN ERROR
13 FREEZER DEFROST ERROR
Run the test and let me know what the test indicated.
Thanks for choosing FixYa.
Kelly
Sep 29, 2010 | Samsung 26 Cu. Ft. Side-by-Side...
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
Heating & Cooling Logo
1,580 people viewed this question
Top Lennox Heating & Cooling Experts
Lawrence Oravetz
jeff5may32
tractorman44
tractorman44
Are you a Lennox Heating and Cooling Expert? Answer questions, earn points and help others
