Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
  • Fisher and P... Master
  • 3,247 Answers
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Posted on Jan 21, 2013
PABLOCSA
  • 1124 Answers
SOURCE: fischer & paykel dishwasher #DD6031
Try shutting off the power to the dishwasher for a 5 min then see if that resets the control system.... here is a link for the manual.. they have several trouble shooting sections within it to assist you.. http://www.fisherpaykel.com/global/customer-care/product-manuals.cfm
Hope this helps...
Posted on Oct 06, 2008
vitg55
  • 73 Answers
SOURCE: Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Posted on Dec 01, 2008
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
pride applia
  • 232 Answers
SOURCE: F1 problem on Fischer and Paykel Dishwasher.
NO POWER TO LOWER DRAWER, CHECK POWER AT BOARD IN LOWER BACK CORNER BEHIND DRAWER,CHECK FOR BROKEN WIRE TO LOWER DRAWER,CAN ALSO BE THERMAL FUSE ON HEATER PLATE,COULD ALSO BE CONTROL BOARD IN LOWER DRAWER.GOOD LUCK there is a drawing taped inside behind the drawer. oops sorry about all caps prideapplianceser@sti.net
Posted on Jan 01, 2009
SOURCE: Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Posted on Apr 21, 2009
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on my Fischer Paykal drawer dish washer . This is the flood sensor . It was. tripped when water was splashed in a plug that shares the same Circuit. How do I reset the sensor?
Not sure if the flood sensor will trip if the water is splashed into the mains plug. F1 can also occur if the power to the top drawer has failed. Flood sensor trips when water collects at the base of the dishwasher housing under the bottom drawer.
I think the problem you mention has caused the power to the top drawer to fail due to a spike when the splash on the power plug occured. This is very easy to see. Check if the display on top drawer is blank.
Nov 04, 2012 | Fisher and Paykel Dishwashers
Machine powers on by itself both drawers.. with the error message
F1 can mean two things - depending on which drawer it is coming in.
It is a sign that the water is leaking from the drawers into the base of the housing and tripping the flood switch.
To fix this you will have to take the drawers out and dry out the flood switch at the base of the housing. Use towels and hair dryer. Most like the dishwasher detergent is foaming or the door seal is leaking or the outlet drain is cracked. Make sure the mains power is turned off when you are working on the dishwasher.
The other reason is if the thermal cutout is blown in the lower drawer that can cause the F1 to appear in top drawer. But if both drawers are flashing F1 then this is unlikely.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
Showing f1
The f1 fault is cased by a leak on the dishwasher.
It is activated when water gets to a dangerous level in the base of the appliance near to the PCB.
The main reason this happens is putting cups on the drop down shelves and when the lid comes down to seal the drawer it can't and leaks. If you look at the drawer when open there is a lip around it, if anything is proud of this lip the lid will not shut properly.
To rectify this problem you will have to disconnect the power and remove the bottom drawer and the dry up all the water in the base. If you leave the appliance long enough it will dry out by itself.
Once you have done this and the problem still comes back you will need and engineer as there is a problem with the lid motors or the seal’s.
Good luck hope this helps..
Mar 21, 2010 | Fisher and Paykel AeroTech Double OD302...
F1 flashing
Mar 04, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dec 29, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
73 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
