Question about Maytag Neptune MAH5500B Front Load Washer
Washer sounds like jet engine was told it is the drain pump how hard is it to replace
I was told my drain pump is going out of my maytag neptune washer. During spin cycle it sounds like a jet engine. How hard is it to replace the drain pump? Could it be something else?
  • Maytag Master
  • 17,129 Answers
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 17, 2013
duby1990
  • 367 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
SOURCE: I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Posted on Jan 25, 2010
Testimonial: "Thank you. You gave me enough evidence now to get a new washer. Any recommendations? Most reliable front loaders."
FAV6800AWDIY
  • 526 Answers
SOURCE: Maytag Neptune bearing noise
John,
What are the first two numbers of your serial number i.e.10 through 17. I’m an owner like you not a repair person….. but I have a very good feel for machine issues and the repair of the machine. See my ratings under this nick name FAV6800AWDIY and my old original nick name dh1200s.
The biggest problem with FIXYA is they don’t ask the user for Model or S/N of the machine. I can’t believe how many professional repair folks jump in with comments and they have no clue as to what machine is being discussed.
You may end up going with a replacement if it’s the Outer Tub Bearings. I would remove the tub and try to replace before I would junk a $1000 but that’s me you would need to decide. This a weak repair area for me I have not replaced the outer tub bearings on any of the three FAV66800A’s I own but I feel confident I could do it. I buy these cheap and repair for resale.
Have you had the Clutch Pulley removed/replaced in the past for dC or uC error code failure in Spin Cycle?
I would drop the Clutch Pulley out and clean up/re-lube the One-Way Roller Clutches and check for signs of a tub seal leak. Then with the Clutch Pulley out spin up the Wash Basket CCW as fast as you can by hand and listen for bearing noise of the Outer Tub Bearings. Let’s make sure the One-Way Roller clutch bearing is not the bearing noise source. See this post for removing the clutch and doing maintenance and replacement. Clutch Fix Post
I have to post rest of this comment as a comment. This forum is not geared up for DIY responses.
Maytag Neptune MAH4000AWW Front Load Washer Washer will not drain.
Sounds like an object is stuck in the pump. Does the pump activate? Does it try to pump out water. Please let me know.
Jul 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer stops in Midcycle ... water does not drain either
This is more than likely going to be a problem with the pump.The pump is not draining water so the machine isn't progressing any further.The pump may be blocked with something or the pump is seized.
May 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer and the spin cycle is really loud is that normal. Kinda like a jet engine but it is complete level we checked?
you have described the noise from a front load washer in the spin cycle to a "T", it definately does sound like a jet engine. if it ain't broke...don't fix it!!
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Oct 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer, model number MAH5500B
check for a kink in the drain hose. if not remove the front of the machine, remove the the hose that connects to the bottom of the tub and the other end that connects to the pump. feel inside the tub for any obstructions and look into the pump for any obstructions.
Jul 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
177 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
