Question about Janome 8080 Computerized Sewing Machine
Will cords from janome 8000 fit a janome 8080
Can you tell me if the power cord and/or the foot pedal for a Janome 800 will fit a Janome 8080?
Thank you
  • 2 more comments
  • ross_stuff Jan 25, 2009
    No, the answer is not helpful. I asked about 2 cords specifically between a Janome 8000 and a Janome 8080. They either are interchangeable or they aren't.
  • Anonymous Mar 15, 2014
    Janome mc11000 loses the center position
  • Anonymous Mar 16, 2014
    fix janome 6125 continues to sew after foot pedal is released
  • 66 Answers
Some of the cords are interchangeable and the foot petal are also.
Posted on Jan 24, 2009
Janome new home 691 Power cord and foot pedal
try checking a1sewingmachines.com and call them about the parts you need.
Jul 12, 2013 | Janome Sewing Machines
My janome sewist 509 is running really slow almost at standstill what can be causing this
could be the power cord not being plugges into the machine
enough or the power cord is going out
or it could be the foot pedal is going out
it would be a good idea to have the machine checked
Jun 27, 2012 | Janome Sewist 500 Sewing Machine
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
How do I attach my embroidery foot to my Janome 8080?
if its like the 8000 and 9000, you unscrew the metal part that clips onto the foot, and attach the plastic embroidery foot ( P?) instead. It does not just clip on like other feet. the screw holds the embridery foot in place
Sep 17, 2010 | Janome 8080 Computerized Sewing Machine
Lost Power Supply Cord
HERE is a link to 24 options in Lakewood area
...........any Janome dealer will be able to supply a power cable, do you also need the foot control ?
HERE is Janome Dealer Locator site
Best Wishes
www.bargainbox.com.au
Nov 13, 2008 | Janome 8080 Computerized Sewing Machine
New home 8000 memory craft embroidery machine
Locate a Janome dealer and have him order them for you. The power cord can be purchased from Radio Shack if the dealer doesn't have one.
sewman7
Jul 19, 2008 | Janome Memory Craft 9000 Computerized...
Janome 8000 mc
Solution #1 worked for my Janome 8000 Thank You
Sep 12, 2007 | Janome 8080 Computerized Sewing Machine
Janome 8080 Computerized Sewing Machine Logo
304 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
