Question about Dynamo MartinLogan Subwoofer Speaker
How is the power supply cable. Is it a special cable?
Everytime I am turning on the subwoofer it burns a fuse
8" compact subwoofer not working it was installed
post more information about your amp. its likely the vibrations moved something in the amps, or buttons.
Oct 10, 2013 | Alpine Swe-1000 8" Compact Subwoofer...
My klipsch ten inch subwoofer is making a high pitch whinding sound when the sub is turned on
my fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
Aug 01, 2012 | Klipsch Synergy Sub-10 Subwoofer Speaker
My Subwoofer Sony SA_WM500 was always burn the fuse therefore I had to change the STK, but now it takes off sound very low, How can I have back the high sound level? Zaruque Quimuenhe
It's no clear what you mean by "I had to change the STK", but if that means you have somehow defeated the fusing or place a larger fuse than it requires then STOP and shut it off. You might be risking a fire or more serious damage to the amp.
I would recommend you find a hands-on tech to look at it.
If you have resolved the fuse problem and now just have low subwoofer volume, you might want to track it back to the source and ITS subwoofer volume setting. There IS a volume level control on the sub, too. Turn it up.
The manual is here:
http://www.retrevo.com/support/Sony-SA-WM500-Subwoofers-manual/id/752ag404/t/2/
Jan 11, 2011 | Sony SA-WM500 Subwoofer
Sony SA WX 700 - Fuse (6.3 A 125V) keeps burning out
The switching power supply transistors have shorted out. Other parts may be gone also. A difficult fix. Too bad, it's a great sub.
Sep 13, 2009 | Sony SA-WX700 Subwoofer
Ignition fuse burns out.
Check your clutch switch wiring.
Jun 26, 2017 | 2006 Victory Vegas Jackpot
Fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Mar 10, 2009 | Dahlquist ORBIT 5.1A System
Subwoofer will not turn on
Does anybody have a solution to this problem?
Jan 05, 2009 | Yamaha YST-SW45 Subwoofer
Burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Apr 02, 2008 | Sunpentown 11 in. SR-1330 Electric Cooktop
Fusion Amp Starts In protected Mode
check remote wire coming from back of radio
Jan 08, 2008 | Fusion FEW12PK Car Subwoofer
Dynamo MartinLogan Subwoofer Speaker Logo
51 people viewed this question
Top Dynamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dynamo Audio Player and Recorder Expert? Answer questions, earn points and help others
