Question about ASUS X83Vm-X1 Notebook
Asus x83v wont turn on at all
No power at all,think might be the fuse,motherboard or ac plug/jack.
  • ASUS Master
  • 7,627 Answers
Try another AC outlet, Try another Cord/charger with the EXACT same power specs. If the AC jack has been damaged due to pulling on the AC cord, you may have to replace the AC jack. Most likely, there is no in-line fuse in a laptop.
Posted on Jan 17, 2013
5 Suggested Answers
Geekinator
  • 183 Answers
SOURCE: I have a ASUS X83V with Vista 64 bit laptop. The
Hello there tls2004.
Here's your geek-steer ...
Contact in order:
  1. Vendor from which you purchased your system.
  2. ASUS Support.
It will likely cost you though. However, ask for a break (free) "in the nature of good-customer relations", and how "impressed and appreciative" you'd be (particularly if recently aquired). You won't know unless you try. It works more often than you'd imagine. Especially if vendor, and they have an unnecessary extra just lying about.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Posted on Oct 03, 2009
Testimonial: "I have searched their website @ asustek with no luck."
  • 69 Answers
SOURCE: My ASUS X83v laptop wont start up, it keeps rebooting.
Try booting in safe mode...if you are able to get into safe mode without it rebooting then you have a driver problem, Try updating all drivers and see if that works. If you can't even get into safe mode, then it could be either, Bad RAM, Motherboard, Corrupted Hard drive or power supply.
To trouble shoot Ram, if you have more than one piece, take all out except for one and try it, if it works, then try the other piece of RAM in the same slot, then try both in the other slot, this will tell you if it's your RAM or your RAM slot.
Motherboard, not much you can do
Corrupted Hard disk, try booting into safe mode with command Prompt and run chkdsk utility on your drive
Power supply, make sure the battery is charging, if possible try another battery fully charged for the same model, remove battery and plug laptop in, unplug and just use battery..
Hope some of this helps you
Posted on Apr 15, 2009
emissionwiz
  • 79077 Answers
SOURCE: asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Posted on Jul 12, 2012
My hp compaq tc4200 wont turn on.if i plug power cable it shows charging after few seconds it wont charge i removed battery but the problem still
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test your compaq tc4200 power supply with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 08, 2013 | HP Computers & Internet
Asus laptop won't power on
Possible causes:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Dec 21, 2012 | Computers & Internet
My hp netbook wont turn on, what shoud i do?..
Possible causes:
Replacement HP Mini 210 AC Adapter Cord 30Watt 19V 1.58A
Nov 05, 2012 | HP Mini 210-1030NR Netbook
My asus g1 laptop wont turn on and the power light wont turn on either but when i opened up the motherboard its passes electricity through some parts of the motherboard
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place....
Oct 31, 2012 | Computers & Internet
MY ASUS F5VL MOTHERBOARD WON'T TURN ON???
Possible causes:
AC adapter failure.
Power jack failure.
Oct 30, 2012 | ASUS F5VL-A2 Notebook
My Asus Altec will not power up is there a reset on this laptop. it's not that old so I don't think the battery is dead. and I don't think is a problem with the power supply
There is no reset as such, however you can try the old trick of removing the battery and ac adaptor, pressing the power on button and holding for 30 seconds, then reconnecting the mains supply (not battery) and see if it will then boot.
If this fails, you need to check the following:
  • check the power supply, the led should be bright green and not flashing, if it is, suspect the power is not reaching the laptop.
  • Check the security of the dc jack as it enters the laptop, if loose or sloppy, the jack port will need replacing
  • With a multimeter set to 20 volts,and the power supply plugged in, touch the RED terminal of the meter to the INNER part of the jack and the BLACK terminal to the outer of the jack. Getting less than 20 volts (give or take a couple of volts) means the adaptor is not putting out power.
  • If this fails, and / or you try another adaptor and it fails also, you will need to open the laptop. (google for a manual on this or you tube video)
  • On the motherboard, there will be a small ceramic fuse near the DC jack, using a multimeter set to OHMS, touch one probe to to one side of the fuse and the other to the opposite side, you should get a reading, if not, the main fuse is blown and will need replacing. (There may be another fuse near the battery, test this also to prove the battery circuit is working)
  • If the fuse gives a reading, I THINK this laptop has a DC jack with wire to motherboard not soldered onto the board, again using the multimeter set to OHMS, probe the positive (inner part of the jack socket) and connect the other probe to the terminal that connects to the motherboard (positive terminal) There may be 4 connections, 2 neg and 2 pos.
  • If the test fails, replace the socket.
After that, the likelihood is that there is a fault on the board and will need more specialist investigation
Jul 18, 2011 | ASUS K52n-a1 Notebook
How do you dissasymbule the asus x83v to replace the dc powerjack
the dc power jack on many motherboards is soldered to the motherboard itself. it requires many tools and errors will result in the laptop becomming non functional. recommend taking the unit to an authorized repair center.
Mar 05, 2011 | Computers & Internet
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Apr 15, 2009 | ASUS Laptop with Intel Centrino Processor...
ASUS X83Vm-X1 Notebook Logo
220 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
