Question about HP Pavilion dv4000 Notebook
Wont charge anymore? hp dv 4000
My son drop my note book and it wont charge anymore? I plug the charger in but nothing happens, once my battery dies that's it I guess!
  • rg42394 May 11, 2010
    Are you under warrenty?
    Problem Solver:
  • 4 Answers
Does the computer acknowledge when you plug it in? Are there any status lights indicating AC power? If not then the electrical contacts in the laptop power plug may have broken. If you are not under warranty, you could take a peak inside the case where the connector is and possibly fix it with a soldering iron. In the meantime I'd backup any important data.
Posted on Jan 24, 2009
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
My nikon coolpix S220 wont charge. I had to buy another USB connector because my son lost his and it does not seem to recognize the camera at all and will not charge
The camera does not contain any charging circuitry and will not charge the battery when connected via the USB cable. In fact connecting via USB actually drains the battery faster because the camera has to communicate with the computer (even if only to say it has nothing to say).
The camera comes with a separate MH-63 charger. Take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet. Once the battery is charged, you can put it into the camera and try connecting it to the computer.
Better yet, don't connect it to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Not charging
No, there is nothing wrong with your charger. Its a voltage irregularity problem. Once it happens next time, remove the charger, remove the battery, put the battery back and try again.
I use HP 530, and I experience the same problem once in while but not every time.
Good luck.
Mar 17, 2010 | HP Pavilion g60-440US Notebook
Hello.Why wont my ipod nano turn on?
thanks for using fixya to solve your problems, i think the battery is down and need to be charge before you cn power on your ipod again. connect the charger or adapter to the ipod and plug it to AC power supply, leave for a while or some minutes before you power it on.
NOTE: don't always allow your battery to run down before you charge it.
Compliments and best of luck
Dec 24, 2009 | Apple iPod nano
My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i...
I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
Nov 09, 2009 | Apple iPhone 3G
Screen wont come on
Does it only light up when you adapter is plugged in? If so try taking out the battery and making sure it is in correctly. Press the power button under the screen on the side if the unit and the middle circle in the directional key pad, there should be a menu that comes up.
Jun 17, 2009 | Jazz DV-179 Digital Camera
Digital screen doesn't light up!
A common problem is battery drain. This is caused by a leaky component on the circuit board. Replacing the board is the only fix.
Jan 09, 2009 | Aiptek PocketCam DV Digital Camera
My jazz179 wont charge and it wont come on its so dead....should i return it?
Well, either the battery is out of place, or the battery has been recharged inproperly, no battery life left, or it has been charged to long. Try getting a new battery? Maybe that will help.
Questions go to
www.palliekilla.webs.com and go to the guest book.
Dont forget to leave your FixYa name.
Mar 15, 2008 | Jazz DV-179 Digital Camera
HP Pavilion dv4000 Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
