Question about RJ Tech RJ-4200
RJ Tech RJ-4200 II manual - RJ Tech RJ-4200
  • Cindy J Jan 18, 2013
    Where can I find a manual for RJ Tech RJ-4200II?
Sd 4200
Make sure your DVD player has HDMI or Component RGB output,you will also need RGB component cables or HDMI cables to connect the DVD player to your Vizio,once you have attached one of the above cables you will need to press the input button on your TV'S remote to select either HDMI or Component.
Jun 07, 2012 | RJ Tech 4200 DVD Player
I have the RJTECH 4200 Karaoke Machine. Worked fine for over a year and recentlt loaded a CD and the power shut off. Tried everything, can't get it to turn on. Need help on getting repaired. p.
A repair if total dead is possible. Follow the money or the voltage in this case from cord to switch and from there to power supply--should be AC or wall voltage up to the power supply and then get rectified (changed) from AC to DC.
If no AC voltage past the switch--test it with a ohm meter--off no reading, on a reading etc.
May 27, 2012 | RJ Tech RJ-4200
No sound from microphones
FIXYA ADMIN CHECK. Q APPROVED.
Jan 15, 2011 | RJ Tech IVIEW1800HDII RJ Tech...
I have dish network and i want to put my dvd RJ Tech at my remote control but i can't to find the code for this dvd can you help me with this ? My dvd is a RJTech RJ800dvx thks
It would be our pleasure in helping you with this. We currently do not have any codes your RJ Tech DVD player; we would recommend performing a power scan. A power scan determines if there is a code that will operate your RJ Tech DVD player.
Power scan instructions:
Step 1:
Press and hold the DVD/VCR mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sep 17, 2010 | RJ Tech RJ-800DVX DVD Player
I have the rj 1500 dvx II- I'm having trouble with the cd tray not being able to eject, seems to be stuck for some reason. I don't remember how long ago I bought and wanted to see if they have a warrantee...
Normal warranty cover maybe for a year unless extended. What could be tried is to open the side screws and remove the covers. Then you can see the loading mechanism , the main loading off the CD mechanism is coupled to the eject drive. So only after the optical head moves down will the Cd be able to come out with the tray. So look carefully and you will be able to trace the logical solution to manually turn the gear to move the mechanism to eject. If there is no jamming of the mechanism, tighten all connectorrs just to confirm the connections. If not the loading motor or the motor drive IC/controller IC is faulty.
If not familiar try to search on web for nearest service centre.
Hope you try this out. Good day
Aug 19, 2010 | RJ Tech RJ1500 DVD Player
Picture moves vertically
if teh picture is also black/white, then it's set to the wrong system: press teh N/P button on yoru remote ... hopefully that will fix the problem
Oct 22, 2008 | RJ Tech RJ-4200
I do not here my voice in microphone
you have to play around with the volume buttons on the remote. Turn down the volume from the dvd player using the vol - button then turn up the mic volume on the front of the machine
Oct 12, 2008 | RJ Tech RJ-4200
New microphones will not work
http://reviews.cnet.com/dvd-players/rj-tech-rj-4200/4505-6473_7-31490033.html
Aug 22, 2008 | RJ Tech RJ-4200
Universal remote control code for RJ-3700
I heard that no universal remotes have codes for RJ-TECH products. Also each remote has separate codes for each brand was told by another person, My remote broke as well and I found that a lot of remotes around the house had certain buttons that did different features on my dvd player. So if you have a remote which can record the infared codes for each button (Macro codes or something) that would work but I am not sure if there is a way to get the exact buttons on a universal remote to work on the dvd player. The second option is buy a universal remote from RJ-TECH if they sell them. I am just about to check for myself now, if they dont have 1 I'm buying a new DVD player cause its usesless if I cant control all the features without a remote.
Mar 19, 2008 | RJ Tech RJ-3700 DVD Player
How to switch back to NTSC from PAL without being able to see player menu
Solution to resetting TV type for RJ Tech
  1. hook up unit to computer monitor (not a TV)
  2. power up, remove any media from the tray
  3. select setup menue
  4. for TV type - select NTSC
  5. for TV output make sure CVBS S-Video is selected
  6. exit setup
Oct 28, 2007 | RJ Tech RJ-200S DVD Player
RJ Tech RJ-4200 Logo
87 people viewed this question
Top RJ Tech Televison & Video Experts
Electro Med Services...
Are you a RJ Tech Televison and Video Expert? Answer questions, earn points and help others
