Question about Acer Aspire 3102WLMi Notebook
Blue screen xp
Error code 0xc0000006
  • Acer Master
  • 7,627 Answers
If this is the first time, reboot. What preceeded this? Updates? Take a look at this: http://www.almuseo.com/error-code0xc0000006-on-xp.php
Posted on Jan 17, 2013
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
Unmountable boot volume + how to fix. Have reboot CD's Errors messages 0x000000ED, 0x8137DE8, 0xC0000006, 0x00000000, 0x00000000 can't get past this screen. keep circling around F8 and the Dell start-up...
Turn off your pc and take the side panel off and remove the cmos battery leave for three minutes
and then replace this will reconfigure your
motherboard and hopefully solve your problem.
Feb 15, 2010 | Dell Dimension 2400 PC Desktop
I am unable to open operations despite rebotting. There is a blue sereen with various steps none of which have worked. There is an error code 0x000000ED (0x81f14A88, 0xC0000006, 0x00000000, ox00000000)....
Read this http://support.microsoft.com/kb/297185
Since you don't even know what a BSOD is, the safest way for you is to do a clean reinstall of Windows.
Feb 02, 2010 | Dell OptiPlex 170L PC Desktop
I get error bs.exe 0xc0000006 when I try to down
Have you tried running the game in compatibility mode ? (right click on "bs.exe" -> properties -> Compatibility -> Choose to run in windows95 compatible mode)
Nov 03, 2009 | Hasbro Interactive Battleship for Windows
Computer goes to blue screen on start up that says UNMOUNTABLE_BOOT_VOLUME technical information stop:0x000000ed (0x82f944e8, 0xc0000006, 0x00000000, 0x00000000
Do a repair of the Operating System. Insert the OS cd and but from CD rom. when it prompts you for options chose R (Repair). chose the drive you want to repair and at the C:/ prompt type CHKDSK then enter. When done restart the system.
If this fails try a second level repair by reinstalling the OS but you will still retain your files
Oct 24, 2009 | Microsoft Windows XP Home Edition
Dell Dimension 9100 Blue Screen 0X00000024,00190293,86FA5B30,C000102,00000000. I tried to reinstall XP from CD and it says unable to locate Hard drive. Replaced Hard drive and tried again, same message....
Hope this help you...This is in relation to what your error code means, you'll need to check against the list.
  • Error 0x00000024 - This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
  • Error 0x00000004 - occurs because your computer processor detected and reported an unrecoverable hardware error to Windows
  • Error 0x0000007b - occurs if your computer is infected with a boot-sector virus.
  • Error 0x80004005 - occurs because the account that is being used to access the page does not have access to the HKEY_LOCAL_MACHINE\SOFTWARE\ODBC registry key.
  • Error 0xc0000005 - occurs because of memory corruption.
  • Error 0xc0000034 - caused by a missing system file (usually Ntdll.dll in the %systemRoot%\system32 directory.
  • Error 0xc0000006 - occur if there is not enough free hard disk space on the NTFS-compressed hard disk partition when the SIS filter tries to read compressed back pointer data streams from the SIS volume.
Another common reason can be malware and spyware that penetrate to your computer registry and started destroying it... that's why it's so important you fix your registry right now!
trust this help.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Blue screen on dell svc tag:GSKTL1S.Ox000000ED,0x8734D9EO,0xC0000006 how to fix this error?
Fine..You have reached the Blue Screen of Death (BSoD)..common in Windows Operating Systems. Generally this must be a hardware problem. If parts liek RAM or bad sectors in Harddisk, such BSoD comes, indicating the crash of the OS. Try repairing XP using the cd. If not, go for a format so that the bad sectors in the Hard disk is repaired.
Thank you!
Sabharish
May 30, 2009 | Microsoft Windows XP Professional for PC
IBM ThinkPad T30 2367
I bet your hard drive crashed on you. You might have to buy yourself a new hard drive and replace your old one with it. Then format it and install a fresh copy of your Operating System on it. Your error condes here indicate to me that you either got a blue screen or similar. Blue Screens and/or the code that you stated here are usually caused by a software issue, and are rarely hardware issues. But in this case, you may have gotten something bad on your computer, such as a virus or serious spyware, that wiped out your Operating System And caused your hard drive to crash/become corrupt. As I mentioned, try replacing your hard drive. Hope this helps.
Sep 07, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba PSA60L-004003
1. Try removing the memory
2. Try removing the hdd (try to use another ide drive)
3. try removing the cdrom
In that order try to remove them clean them, or use a spare, and see if the error pops up again.
Apr 09, 2008 | Toshiba Satellite A60 Notebook
Acer Aspire 3102WLMi Notebook Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
