Question about Evenflo ExerSaucer SmartSteps Active Learning Center
Evenflo exersaucer smartsteps battery cover
I'm looking for the battery cover on the toy bar
SOURCE: I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Posted on Apr 19, 2009
MazzyA
SOURCE: how to remove the seat cover on exersaucer
Hi, all the way around it are plastic bits sticking out and the seat cover is clipped onto the plastic bits, just lift them off one by one, all the way around. then when your done clip them back in again. hope this helps.
Posted on Jun 16, 2009
SOURCE: Evenflo exersaucer with animals and a jeep which
It's a little tricky and you'll end up ruining a couple of hte stickers. This is what you'll need to do -
1. Pry the latches loose under the top that hold the jeep in place
2. Unscrew the 4 screws that hold the jeep to the base
3. 2 of the wheels have screws - use a small screwdriver to remove these
4. The window stickers on the same side as the wheel screws cover 2 more screw holes - you'll need to feel for these and poke holes through the stickers to get to the screws.
5. Once you remove all these 4 screws, the jeep should come apart in 2 halves. Dont exert too much pressure while separating them.
6.The inner assembly (purple with gorilla) slides out of the body of the truck. The base of this assembly has 3 batteries that you'll need to pry out and replace.
Posted on Dec 02, 2009
  • 100 Answers
SOURCE: I'm looking for an online assembly manual for my
You can try this link. It will be helpful if you know the model number to the exersaucer you have. https://plweb.evenflo.com/replacement_parts.aspx
www.evenflo.com is a good website check it out it has a lot of helpful information. Please tell me if this works for you ok.
Thank you
Posted on May 05, 2010
SOURCE: need to find replacement toys
E Bay carries lots of replacement parts for these items. Most are new.
Posted on Mar 20, 2011
Where are the batteries in evenflow ultra saucer
file:///C:/Users/erwooster/Downloads/25707060.pdf
States batteries are not replaceable, which means that they are buried somewhere inside the main module. Proceed at your own risk.
Nov 15, 2013 | Evenflo ExerSaucer SmartSteps Active...
I washed the seat cover of the exersaucer and cannot get it back on
It has likely shrunk. Try wetting it and then stretching it on while it is wet. Let it dry while it is on.
Jan 03, 2011 | Evenflo ExerSaucer SmartSteps Active...
Need to know where to get it and how to figure out
Are you sure that one spring is not inside the other? I almost had that problem
Nov 06, 2009 | Evenflo ExerSaucer SmartSteps Active...
Lost the directions to turn the toy into stage 3.
flip it over,there has to b a way to unclip the bottom.
Jul 26, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
How do you change the batteries in the exersaucer circus tent?
on the back you should see a screw that is by its self try un screwing it and replaceing tyhe battery
Apr 03, 2009 | Evenflo ExerSaucer SmartSteps Active...
Need replacement part,a spring for Evenflo Exersaucer Mega Activi
Check thier website. You can enter in the model # and date of production (seat ring that the cloth attaches to). From there it'll show you all the available parts for purchase. You can also find/buy replacement or "switch a roo" toys from their website. I found this by googling "replacement parts for evenflo excersaucer".
I hope this helps!!!
Jan 04, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Evenflo ExerSaucer SmartSteps Active Learning Center Logo
Top Evenflo Toys Experts
ka4iup
ka4iup
john h
Bill Boyd
Are you an Evenflo Toy Expert? Answer questions, earn points and help others
