Question about Pentax K100D Super Digital SLR Camera
K100d time backup battery - Pentax K100D Super Digital SLR Camera
I have Pentax 100D and using Ni-MH battery. But battery is going empty very quickly after few photos
Sounds like, due to age, the batteries aren't able to hold their charge well anymore. I'd suggest picking up a new set of Ni-MH batteries.
May 10, 2011 | Pentax K100D Digital Camera
Why can't i see what i am taking a picture of by the lcd screen?
That feature is called "Live View". The K100D camera does not support that feature.
More specification information can be found here
Regards,
Jacob
Mar 01, 2011 | Pentax K100D Digital Camera
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
Won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 17, 2009 | Pentax K100D Digital Camera
New batteries fitted but low battery flashing and wont switch on in K100D
Try cleaning the battery contacts in the camera with a cotton swab lightly moistened with rubbing alcohol.
Nov 17, 2009 | Pentax K100D Digital Camera
Camera locked
Put in new batteries. If you're using rechargeable batteries, they already have a lower voltage than regular batteries. If you don't have enough milliamps in the battery, it will show as low, no matter what the voltage is.
Feb 02, 2009 | Pentax K100D Digital Camera
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Bad USB conection?
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Feb 05, 2008 | Pentax K100D Digital Camera
Pentax K100D Super Digital SLR Camera Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
