Question about Generac Electrical Supplies
My guardian propane generator will not turn over when trying to start it?
My guardian propane generator will not turn over at all. I have checked my batery and it is good, I checked to make sure I am hooking the tremianals correctly, the oil level is good and I have planty of propane.
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
CarlGehrke
  • 169 Answers
SOURCE: have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Posted on Dec 05, 2008
SOURCE: Generator will not start
You say there is compression .What was the p.s.i. on the gauge. If below 100 p.s.i.. May have bad ring, valve out of adjustment or bad head gasket. Is there spark and what does spark plug look good, is gap ok . Is the fuel tuned on and kill switch on. Will need more info to help out more.
Posted on Mar 16, 2009
mamicheddy
  • 79 Answers
SOURCE: McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Posted on May 09, 2009
mamicheddy
  • 79 Answers
SOURCE: guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
Posted on May 19, 2009
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Guardian propane generator hard starting. At 20 F backfires and won`t start. Goes to overcrank.
It needs a cold weather option, one that heats the oil and also the carb so the LP gas does not freeze the carb. A common problem
Nov 04, 2013 | Guardian Electrical Supplies
It back fires
If it backfires, check for manifold leaks, fuel mixture is too lean, timing is off, make sure it isn't spitting liquid into the cylinders and the LP is the right pressure, and the vapour coil is working
Oct 05, 2013 | Generac Guardian RV Generac RV Generator -...
My generac generator propane runs good for first min. when cold but when it warms up runs up and down with on rpms.
If it has an "no load" idle feature turn that off and then see if it still has this problem.
Otherwise, Is it outside? The LP regulator may be sticking.
Jan 06, 2011 | Guardian Electrical Supplies
Generac Watchdog 15K, engine will not start
throttle motor or governer board. or control board. your gas line could be to small. check the pressure while its cranking to see if it drops. watch the throttle to see if its moving while trying to crank the generator
Jun 27, 2009 | Generac Guardian 200 Amp Transfer Switch...
Guardian rv generator
May 18, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Have a 16k propane guardian generator have to manually start and
Rate me,
Carl
Nov 19, 2008 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
20 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
