Question about Mitsubishi WS-55513 55" Rear Projection HDTV
TV power remains on but the picture clicks off. I turn set off then back on and picture is up for about 20 seconds then again power stays on but picture clicks off.
It actually makes a small click noise when picture goes off.
  • Caryn Kracinski Jan 18, 2013
    I noticed after picture clicks off it gets purple squiggly lines and the green light blinks to "x ray protect" can you tell me how to fix myself?
SOURCE: Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
Posted on Jul 24, 2007
SOURCE: tv will not power up, shuts off after 10 second
Mitsubishi WS-65857 Do you know why our tv will not stay powered on. We get a green light for approximately 10 seconds, then clicks off
Posted on Mar 02, 2009
SD Tech
  • 14553 Answers
SOURCE: in my WS 65809 projector tv, when I turn on the
DO THIS AND LET ME KNOW WHAT YOU FIND:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If this information has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 07, 2009
SD Tech
  • 14553 Answers
SOURCE: The TV was working great
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Posted on Sep 28, 2010
Testimonial: "The light blinked two times, then 1 time then repeated."
ladywinn
  • 5138 Answers
SOURCE: My mitsubishi wd-65733 is making
Lamp could be the problem or Ballast board that powers Lamp on. Encompass Parts Distribution visit their website and look up your Model#
If Problem is Lamp Mats has them for $99.00
1-800-628-1118
Posted on Oct 23, 2010
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Jun 25, 2009 | Vizio VO47L 47 in. LCD TV
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Aug 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Won't turn off
Go to the panel (on the tv set), hit magic focus on there....then hold power button for several seconds long. It should go off and fix your problem.
Jan 22, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
