Question about Nikon Speedlight SB-600 TTL Flash
Sb-600 and d80 sync, connecting, off camera..
I have the d80 and I just bought the sb-600 and I cant figure out how to sync the camera with the flash when it is not on the camera.. I have the camera on a tripod and the flash on a stand and I am not sure the basics of connecting them.. if anyone can help that would be awesome!
    Scholar:
  • 170 Answers
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Posted on Feb 05, 2009
What the best flash for d80? s sb 800 & 900 compatible for it?
The best flash for YOUR D80 is the one that best suits YOUR needs. Both the SB-800 and SB-900 are compatible with the D80. So is the SB-600, which is lighter and smaller.
Jan 09, 2011 | Nikon D80 Digital Camera with 18-135mm...
I use d80 and flash sb 600 on a bracket and when i take a photo when th lights are dim if the subject is close thier lit up but the rest of photo is dark why?
It's the Inverse Square Law. Light drops off as the square of the distance. If an object is twice as far from the light source it only receives a quarter as much light. So, if the subject is lit properly then the background will be dark.
This is a law of physics. However, there are several things you can do about this. One is to move the light source. Another is to have more than one. The D80 can control other flashes, so you can use the D80's pop-up flash to light the subject and the SB-600 (or more than one of them) to light the background. Another possibility is to bounce the flash off a white ceiling or wall to soften and diffuse the light. Another is to use slow-sync, leaving the shutter open longer to let the background illuminate. You can read more about this in the manual.
Jul 14, 2010 | Nikon Speedlight SB-600 TTL Flash
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Camera flash problem (Nikon)
    ok,
    try to set the menu item for Auto FP to ON (it works in P,S, A, and M modes only) that will activate the Highspeed Sync when you are using the SB-600 flash unit, set the flash mode so the indicator shows the off position (the line thru the lightning bolt symbol) on the top inidcator menu in the its next to the red eye redution icon that will keep the built-in flash off even if you need it in low light. hope that works for you.
    randy320sgi
    Jan 07, 2009 | Nikon Cameras
    Nikon D80 using Bower AF 724AFN
    I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
    May 22, 2008 | Bower (724AFN) for Nikon Flash
    D80 and SB-600 FV Lock doesn't work anymore
    In whacky situations like this it is always best to re-set your camera and flash settings. Somewhere on your D80 you will find two function buttons with small green dots next to them. These are the resets. Push both in at the same time until the display LCD flashes.. The camera is now reset to default settings.You will now have to re-set your FV button to the custom setting you had it at before.
    Also, reset you flash by turning on the power and removing the batteries and re-install them.
    Apr 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    Noise while zooming with sb-600
    sb-600/800 make a distinct motor-spinning noise when zooming, this is normal. Any grinding/clicking noises are not normal.
    Jan 25, 2008 | Nikon Speedlight SB-600 TTL Flash
    Nikon d80 continuous mode
    This can be that the flash sync speed of the camera is not correct. There may not be enough exposure from the flash to the subject during the opened curtain (shutter) sequence.
    Jerry G.
    Nov 29, 2007 | Nikon Speedlight SB-600 TTL Flash
    Mating Metz 60CT4 to Nikon D80 camera
    The 60CT-4 was not made for digital cameras.
    It does TTL on film not on CMOS or CCD sensor.
    Alexander
    atdlee@netzero.com
    Nov 22, 2007 | Metz Mecablitz 60CT4 TTL Flash
    Nikon Speedlight SB-600 TTL Flash Logo
    1,425 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
