I got a 43 yr old Pioneer manual turntable. I have to almost max my speakers to get a good sound. Help
Using a Sherwood RX 4105 for a receiver
  • Audio Player... Master
  • 5,309 Answers
Firstly does the receiver have a magnetic cartridge pre-amp built in? It will have to have a dedicated "phono" socket for this. If it hasn't you need to get one.
The only other cause is a faulty cartidge. You can test this by removing the wires to the cartridge. By touching with your finger each wire, amp on of course, you should hear a loud buzz on two of them one for each channel. If you don't hear any buzz or it's still weak, even if the receiver has a pre-amp, then either the cables to the amp are faulty or the pre-amp in the amp is.
Posted on Jan 18, 2013
2 Suggested Answers
SOURCE: PS-T3 connection to Sherwood 4105 Receiver
You need a phono stage (phono amp) between the turntable and receiver to boost the lower signal from the turntable. If your receiver has phono inputs, use those as there will be a built-in phono stage.
Posted on Nov 20, 2008
Is a Denon most compatible with new Klipsch KB-15 speakers
no brand of receiver is matched to certain speakers. Denon is a decent brand of receiver (but most of the low to mid range models are almost identical to Pioneer inside). Go with a good receiver that has the functions that you need that fits in your budget.
Dec 05, 2013 | Sherwood RX-4105 Receiver
I have a Sherwood RX-4105 Receiver and I am getting no sound through my speakers and the connection with the wires is good so its not that. Any Idea on whats wrong?
when you turn your computer you should hear a sound of a relay initially and after about two seconds another sound, is the closure of the speaker relay models if you do not hear the sounds, the team has some short audio output.
Sep 07, 2013 | Sherwood RX-4105 Receiver
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sherwood RX-4105 Receiver will not stay on
Sorry to be the bearer of bad news but your unit has either a bad power supply or bad transistors and need serviced. Under 200 for the repair however, I'm not sure what the unit sells for new but weight the costs vs replacement. Hope this helps
Jun 06, 2009 | Sherwood RX-4105 Receiver
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
Sherwood receiver rx-4105 fm doesnt pu any frequency (just static) , am does
You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
Dec 17, 2008 | Audio Players & Recorders
Oct 14, 2008 | Kenwood KD-291RC Turntable
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
43 people viewed this question
 Grubhead
Grubhead
