Question about Amana ABB1921DE Bottom Freezer Refrigerator
Took the door off to move and now cannot find a dimension sheet
Need to find something that breaks the refrigerator into something where it would show where the parts should go in order to rebuild.
    President:
  • Amana Master
  • 2,651 Answers
Why does the 'frdge door not open? I have a newly delivered (second one) BUSH BFFF54170S and the refrigerator door only opens about 5cm. Is there something I need to remove? User instructions has no
something may have jared in the delivery process , the baskets, racks etc u can remove the door hindges at top and bottom and remove the whole door to see whats wrong
Jan 14, 2015 | Bush Refrigerators
The top compartment in the refrigerator is cooling effectively. But the lower compartment in the same refrigerator is not at all getting cool. Why is this so?
your damper vent door from the freezer to the refrigerator compartments is either stuck or frozen shut from moisture,sometimes they break and jam too,if this door doesnt open and close your food will get too warm or cold the door needs to move to keep the temperature correct
May 13, 2011 | Whirlpool ET1MHKXM Top Freezer...
Drivers door handle replacement....would like to see how to sheet
on inside of door panel r3-6 screws pull out panel pop off be gental dont break tabs that unclip 1 screw holds handle on unclip rod connecting hanle on out side 2 handle on inside pull out put together how u took it apart
Jan 26, 2011 | 2006 Buick LaCrosse
Fridge not working since i replaced door
Hi I would be checking the switch that starts the light when door opens. good luck
May 18, 2010 | Candy CPCA220K Bottom Freezer Refrigerator
Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator door doesnt close easily
your looking at the door closure
goto www3.sears.com
type in your model
click your choice
open the door plan
look at the bottom hinge
there you should see a break down
order all three parts
when the arrive
take the top hinge off first
lift the door and flip it over
install the new parts
install door your done
the hardest part of this job is not dent ing the door when you flip it over
Oct 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator door gasket needs replacing.
yes.. costs is about $100.00 for a gasket (bought from an appliance store- add 4-6 hours of frustration trying to get the !@#$%^&* gasket to seat flat against the door frame.. Then call the appliance store.. probably about another 75-100$ to have them do it..
Sep 27, 2009 | Amana ABB222ZDES Bottom Freezer...
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Amana ABB1921DE Bottom Freezer Refrigerator Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
