Question about Music Hall MMF-5.1 Turntable
Music hall 5.1 tone arm rewire
Tone arm loom
Rewiring tone arm stanton st.150
Nice , i just received my tonearm wire for a technics. mk5
First question , Which tonearm are you try to put in and why, since if you want a better sound , sell the unit instead of useless replacements and do you use the phono or line out...
Feb 15, 2014 | Stanton Audio Players & Recorders
I have a technic sl 1200 m3d with a broken tone arm, which arms are compatible?
HELLO
Have a look at Originlive on the net. They do an armboard which should fit your turntable easily and enable to put a Rega RB250 or RB300 arm on your machine - it will improve audio quality too!
Apr 29, 2010 | Technics SL-1200M3D Turntable
Have a BC rick I think warlock. Need to rewire
Search this site for one that matches your resources of switches, pots and pickups to find a typical wiring diagram.
http://www.guitarelectronics.com/category/wiringresources/
Feb 09, 2010 | Music
Need Fender Squier Bullet 1 w/3 pickups, 1 vol, 1 tone wire diag
I think this is what you are looking for:http://www.squierguitars.com/pdf/current/Strat/Bullet%20Strat%20with%20tremolo-%20Service.pdf Please let me know if this helps.
Dec 07, 2009 | Fender Squier Std Strat Mn Car
2004 wipers keep blowing fuses chevy caviler
Either the wiper motor or the wires going to it are shorting out. First unplug the wiper motor replace the fuse try the wipers again if the fuse blows again then check the wire loom for a bare wire Check the colour of the wires at the plug on the motor. The most likely place for the wires to short out are at the switch. It may be an easier job to rewire ther wipers as there is a lot of wires in the loom. If you need to know how to rewire it get back to me and I will guide you through it
Aug 10, 2009 | Chevrolet Cavalier Cars & Trucks
No Volume For My Music Hall MMF-5 Turtable
You will need to obtain a phono preamp to connect between the deck and the amplifier. I do not think this turntable is fitted with its own preamp - check the User Guide.
Jan 12, 2009 | Music Hall MMF-5 Turntable
I have a Numark TT200 turntable and when unscrewing the tone arm assembly I noticed a broken black lead. The other three were intact (red green and white). How do I fix please?
Turntabletech.com rewire it thats the option or get the TT200 tone arm base its $149 might as well get a new one with that right?
Oct 16, 2008 | Audio Players & Recorders
Tone Arm
(remedy) ok you can take the whole tone arm (remove the screw under the tunrtable , the rubber and the hard black and  go to the tone arm position (under) there is 3 screw to loosen and then try to burn wher the screw position .i mean take some lighter.but be carefull...
Aug 12, 2008 | Technics SL-1200MK2 Turntable
Music Hall MMF-5.1 Turntable Logo
Top Music Hall Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Music Hall Audio Player and Recorder Expert? Answer questions, earn points and help others
