Question about Harman Kardon JBL Flip black
Flip speaker won't pair
It will pair with ipad not iphone
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
I can't get the speaker to pair to my iPod or iPhone 6
Knownig the speaker's brand and model might help. Presume ithhas bluetooth! Turn it on, press syns if it has this option.
You should have enable bluetooth in your iPas's setting
check if it speaker recognized by iPad and wait them to sync.
Bloutoot device might have a blinking light; should keep blinking till it pairs or reaches timeout.
May 01, 2015 | Cell Phones
How does the wireless jbl speaker hook up with iPhone or ipad
Turn on bluetooth on iPad and press pair button on speaker
Feb 01, 2015 | JBL Audio Players & Recorders
How do I pair my iPad as the second device
Make sure that the headset is not paired with the iPhone (turn off Bluetooth on your iPhone temporarily). Follow the same procedure you used to pair the iPhone, but this time with your iPad.
Dec 26, 2014 | Radio Communications
My speaker does not connect to my ipad
The speaker has to be paired with your iPad before it will work. Check your documentation on how to put your speaker in "discoverable" mode long enough for the iPad to find it. If you have previously paired your speaker and it at one time did function is your iPad, make sure that Bluetooth is turned on on the iPad. Also, check the batteries on the speaker if it has previously functioned with your iPad...
Jun 21, 2014 | iLive Bluetooth Speaker System
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
Can't get my iPhone to Pair with new Jensen SMPS-650
Hold botton down until it flashes blue AND then red it will continue To flash now pair ur headset
Dec 09, 2012 | Jensen Bluetooth Wireless Stereo Speaker...
Iphone won't turn on
Hi
What happens when you try to charge the device?Won't charge?Switch chargers.
Try hard resetting it and see what happens.Here's a video tutorial on how to go about it.
Hope it helps.Thanks
Feb 21, 2012 | Apple iPhone 3GS Black (16 GB)
My iPhone 4 sound isn't work like the clicks when
The problem you have is probably a sound option problem. This is uncommon, but very easy to fix!
To fix:
Turn on your iPhone Unlock it (put in passcode if applicable) Look around, find the app "Settings" Click it, and look for Sounds In Sounds, scroll down, and make sure that "Lock sounds" and "Keyboard Clicks" are switched on, and blue.
If this doesn't work, you've got a speaker problem.
Have a nice day!!
Jul 17, 2011 | Yahoo iPhone Apps
Harman Kardon JBL Flip black Logo
168 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
