Question about Fisher and Paykel (IWL12)
Fisher and paykel smart drive 7.5 Kg washing machine fills with water but wont wash
After filling with water it started to beep and the first green light was on as well as the first amber light and the red end wash light and nothing else. Turned of power for a while then turned back on nothing changed, left power on and during the night the machine came on by itself and started beeping and draining out the water. I have had the machin for about 7 years and has never had a problem before. Can someone help me? please
  • Fisher and P... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 17, 2013
  • Dean Lambert Jan 24, 2013
    Thanks for the info, this is what I have found out so far Water goes in ok pump works ok but agitator not turning, if you put a bit of down pressure on the agitator you can feel gears trying to engage or if you help to turn the agitaor it will rotate very slowly. Thanks for your time
Daniel S
  • 4323 Answers
SOURCE: My Fisher & Paykel GWL11 Washer starts beeping
Hi
The washer is detecting error while it enters wash cycle. You can try and enter the diagnostic mode & check if it resolves the issue. If it doesn't then you would need check for the fault codes.
To enter Diagnostic Mode turn the power on at the power point and off at the console. Press and hold the WASH TEMPERATURE DOWN then press the POWER button. Smartdrive will give 2 short beeps. Phase 1 & 2 Only press ADVANCE button once. From Diagnostic mode press the SPIN buttons until the HOLD and SLOW SPIN LEDs are on, (Diagnostic mode level 3). The WASH PROGRESS LEDs will now display the fault code.
Hope this helps... Please post back if you need further assistance.
Daniel
Posted on Apr 01, 2011
  • 72 Answers
SOURCE: Beeps every second, and won't work at all Fisher & Paykel Excellence 7.5 Smart Drive
the fault is elecrtroic board, as a guess change the electronic board over with an old second hand board
Posted on Sep 25, 2010
jsrock516
  • 5911 Answers
SOURCE: Will not advance from fill cycle
Check your drain hose to make sure you have not sealed the top of the standpipe (drain line), or shoved your drain hose too far down in the pipe. If you do not allow for an air gap, your washer will fill and begin to siphon through the drain line. It is common for folks to seal the standpipe or shove the drain hose down in the line too far in the belief that it will prevent overflows, or get rid of that nasty drain smell. This can be bad because it does not allow for the proper air gap to keep the water from being siphoned right out of the machine. You may have a tight fitting that doesn't siphon every time which may explain why the problem doesn't occur all the time. Double check to make sure. Hope this helps.
Posted on Jun 15, 2007
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Posted on Dec 16, 2008
PSITECHNICAL
  • 71 Answers
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
Posted on Jan 06, 2010
Fisher and paykel smart drive 608 6.5 kgs has running well for ages but recently while finishing water filling it makes a warning beep sound and start leaking from the bottom,anyone there to help me pls
Hi just read your post.Now when the machine beeps a series of lights will light up on the wash progress lights. The spin light is number 8 and the other end of the lights is number 1 which is long wash, i think. Starting from the long wash light which is number 1, which lights are on when the machine is beeping, is it 1,4 and 7 or 3, 7 and 8 etc? Please reply with the answer to this question and i am sure i can help you. Regards Lu
Jan 25, 2014 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
27 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
