Question about Apollo Pool & Spa
I have an apollo spa galaxy AP72L and cannot figure out for the life of me where the filter is and how to fill it!!!! we went to the apollo spa store and they said it would be on the top of the spa but there is nothing there!!! HELP
  • Apollo Master
  • 1,631 Answers
Check below the basket or as some call it, the plastic strainer.
Posted on Jan 22, 2013
How do I backwash an Apollo VA-52-2 without sending dirty water back into the pool?
make sure filter connected correctly if ok after backwash then rinse if dirt goes into pool bad filter elements or multiport
Jun 03, 2017 | Apollo Pool & Spa
My Apollo Spa shuts off and on when high speed is pushed. I replaced pump and it is the same. Any help is appreciated.
Check your voltage to that pump. If the pump is set to accept high-voltage of 240 V, and you are only providing low-voltage of the 110-120 V then you will be getting that symptom.
Apr 12, 2015 | Pool & Spa
My apollo spa galaxy II D20Nj will not heat past 85 can you tell me what I should do or part to get to fix this serial #BSJLJEG
make sure spa setting is at 104 degrees if at 104 degrees see control system if ok change temp sensor either in heater or control unit
Dec 07, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a 300GAL Spa that was installed on a 120v 20amp two pole. I had a 240v 50amp breaker that I replced with two 120v 20amp breakers, we wired the tub and the pump works but when the heater is turned...
What is the amp rating for the tub? What voltage are you actually running the tub on, 120 or 240? Is the 120v 10amp two-pole then the switch rating since you mention a switch? If there is no amp rating on the control what is the wattage of the heater element and how much horsepower is the pump rated for?
In the end it seems likely you do not have high enough breaker ratings to carry the pump(s) and the heater at the same time. Depending on the electrical circuit wire size and the breakers and switches you may need to make some adjustments or replace some of the components but I'll/we'll need more details on your existing setup and the tubs electrical demand to help you further.
John
Mar 28, 2011 | Apollo Pool & Spa
I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Oct 29, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
How to clean a Anthony Apollo diatomaceous pool filter pump
Drain tank. Remove the retaining band from filter. release locking lever securing support shaft and lift straight up wiggling slightly. the filter grids will come out as a unit. A most satifactory cleaning can be done without disassembling the grids. Just hose of all surfaces with a strong spray of water. Clean out de from tank bottom. Clean tank o-ring, lube and reinstall grids.
Mar 25, 2009 | Pool & Spa
Pool & Spa Logo
170 people viewed this question
Top Apollo Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Apollo Pool and Spa Expert? Answer questions, earn points and help others
