I have a rinex rx74 tv with resistor R315 burnt . What is the value ?
    Top Expert:
  • Televison & ... Master
  • 75,471 Answers
To which section this resistor fitted. horizontal out? If so, it should be of 2 to 3.3 Ohms 5W.
Posted on Jan 17, 2013
  • 76 Answers
SOURCE: Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
TVtechmaniac
  • 140 Answers
SOURCE: No Pic...power light only, on plug in
R414 is a 13K ohm 1/6 watt resistor.
Posted on Sep 28, 2007
  • 2336 Answers
SOURCE: Burnt out resistor
I was not able to find a free service manual download. Here's is a site that has the service manual but is a pay site. click here.
Posted on Jul 03, 2008
SOURCE: Resistor value
the value of r404 is 10 ohm 1/8 watt
Posted on Dec 18, 2008
  • 5603 Answers
SOURCE: Burnt Resistor
There are LIKELY other bad components that caused this. Resistors USUALLY don't fail on their own.
Posted on Jan 30, 2010
Burn Resistor 842 conot find the value
You can get the value of this resistor from the circuit diagram of your model TV.
Usually a burnt resistor is caused by some other component failing that is connected to the resistor.
Apr 19, 2013 | LG Televison & Video
Hilti TE-5 burnt resistor value
Hilti should be able to supply that information.
Jul 24, 2012 | Drills
Need to replace 2 burnt resistors in my Samsung hcr4755w widescreentv,how do i find what value resistors they are, where to findfreeschematic for this TV?
You wont find a free manual give me the R #s labeled on the board where the resistors are located. I hope you have have found out why the resistors burned ...first!
Jun 04, 2010 | Samsung Televison & Video
Burnt Resistor
Jan 30, 2010 | Toshiba 32A33 32" TV
The blue convergence seems to be off on the tv, and i'm not sure how to fix it
Take the back of the tv off but first unplug it Then look to the lower right and you should see 2 convergence IC's (STK392-110) and also look for a burnt resistor around them. If no burnt resistors replace convergence IC's with STK392-180 If you have a burnt resistor then respond back to me with location number on the board and I will get back to you with the value.
Jun 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Burnt resistor
You have to check what could cause these resistors to be burnt. It might be because of caps or IC. Unfortunately, I don't have this type of circuit board. If you cannot find it, try with the same value of resistors that are placed close to these fault resisters.
Mar 16, 2008 | Computers & Internet
Aug 19, 2007 | RCA F31317 31" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
