Zenith 25" model z25x22s has hardly any green
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
Check the green output section circuit at the video output card for any loose soldering. This card can be located at the neck of the picture tube itself, will directly plugged to it. You can pull it out of it for repair. Re-solder all the suspected solder terminals there.
If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Posted on Jan 17, 2013
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Zenith 25" Color TV - Model A25A23W
Your problem is a bad connection on the CRT socket on the CRT driver board, a bad connection in the RGB driver supply from the video jungle IC or maybe even an intermittant Picture tube. the only way to tell would be to tap on the crt board while the sets playing with a non conductive insterment, and see if it changes. Now there is alot of HIGH VOLTAGE at this spot, so if you have no TV repoair experience Please stay safe and call in a pro to assist you. Good Luck Please dont forget to rate this thread.
Posted on Nov 12, 2006
SOURCE: Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Posted on Aug 12, 2008
Maciso
  • 125 Answers
SOURCE: Sony with color problem
if the color is only green most probably the green crt is bad, the cost is about 180.00 plus the labor
Posted on Dec 17, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: 16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Posted on Apr 10, 2009
Where is the vertical adjustment knob on the Zenith Z25X22S and how do I get to it?
many new TV's having vertical hold most of the case you need service mode to change the setting
Aug 24, 2010 | Zenith Z25X22S 25" TV
DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Mar 15, 2010 | Zenith Z25X22S 25" TV
The sscreen does not have any geen color. Everting onthe screen is either Blue or red
if you are conected via an RGB or an RGBHV cable, check that one of the R (red), G (green) or the B (blue) is short it.
Sep 17, 2009 | Zenith Z25X22S 25" TV
Need manual for zenith z25x22s
need code for a 1997 Z 25 X 22S Zenith TV .
Have the remote , bought used tv , but remote is not working . It has a prgram buttom on top left of remote
Jul 03, 2009 | Zenith Z25X22S 25" TV
Programming stock remote
Most original remotes are non-programmable. I would get universal for $5-10
Jun 11, 2009 | Zenith Z25X22S 25" TV
No Picture
This is a problem with the vertical circuit. If you can solder, you should be able to fix this. With teh unit unplugged, open up the back and locate the vetical IC. This should be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering hte pins. If that fails to resolve the problem, replace the IC. I will look up your specific model and try to get more details.
Dan
Sep 16, 2008 | Zenith Z25X22S 25" TV
Zenith tv, video retrace lines.
how is the 200 volt supply to the video output transistors??
measure the collector voltage of the video output transistors with the crt board on and off the crt. if voltage goes up when crt board is off then crt shorted
Apr 28, 2008 | Zenith Z25X22S 25" TV
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
