Question about Garden
One day when i went to start up my stihl weed eater it wouldnt pull so i took the plastic peice off and ther is a spring maybe or something right next to the pull cord and it was not on anything i pulled it and its about 6 ft long now and i cant get it in right please help i dont understand how to fix this.
    Sergeant:
  • 322 Answers
First off what model of trimmer is it? an fs what? second, if you are talking about the recoil spring you will need to go to a STIHL dealer and order a new one. If it came off one end then that means it broke and needs to be replaced and if it isn't broken but now uncoiled replacing it will be easier then trying to rewind it and put it back together
Posted on Jan 17, 2013
SOURCE: I have a Troy Bilt TBP6040 XP 4 cycle weed eater
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Posted on Jul 23, 2009
pumpkinman
  • 1144 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
moretons
  • 155 Answers
SOURCE: Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Posted on Jul 26, 2009
agent91
  • 2100 Answers
SOURCE: My Ryobia SS30 SS# ATJ0830439,weed eater, the pull
http://www.ereplacementparts.com/ryobi-ss30-ry30002-string-trimmer-parts-c-7931_15633_15651.html
This is a parts site for you with a schematic so you can see what is going on. I think your return spring is either broken or out of it's keeper. Check it out. hope this helps.
Posted on Apr 28, 2010
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
My stihl weed eater fs85 hard to start when hot
Try loosening the gas cap to relieve any pressure, then tightening it back up. Usually you will just need to barely unscrew it and then screw it back even before you pull the rope.
Jul 13, 2014 | Stihl FS 85 Weed Eater
Needing break down on starting assembly! My start cord is fine, but dose not grab anything when I pull.
Danny by the pull cord on the back are two wings that come out when you pull the starter. They are on springs and fly out to grab the wheel. Spray these with lube oil and then let them rest for 10 mins then try.
Oct 17, 2013 | Stihl FS 85 Weed Eater
Hard to start weed eater
check for proper starter proceedure.some models are very specific to starting proceedure.if the equipment does not run to warm up or if the chike sequence is improper it will not start
Sep 09, 2012 | Stihl FS 85 Weed Eater
Jul 25, 2009 | Black & Decker Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
