Question about Frigidaire Washing Machines
Oil in the bottom of the washing machine
GLWS1339CS1
  • Frigidaire Master
  • 17,130 Answers
Possible that this had come out of the gear box or the spindle section. If so this section must be reset, the drive and motor must be checked.
Posted on Jan 17, 2013
Oil in the bottom of washer
The oil is leaking out of the agitator gearbox. The water is coming from the seal on the agitator. I think the gears are badly worn..
Nov 19, 2013 | GE Washing Machines
Glws1339cs1, started making noise like a belt was slipping during the spin cycle
Hello Bill Johnson - Is the washer draining or spinning? Could it possibly be a humming noise? If it is not doing either or and making a humming noise then it could possibly have a restriction in the drain line. Or either the belt is loose and will have to be put around the transmission and then spin it on to the motor or there is an issue with the lower/upper bearing. I would suggest contacting a professional to move forward accurately to properly diagnose/repair the washer.
Nov 12, 2012 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
My Frigidaire GLWS1339CS1 fills but stops about 2 inches from the top? It has done this since I bought it and otherwise works fine. A tech came out and told me to fix it would cost more than buying a new...
The washer will not fill all the wayto the top.yourmachine is functioning properly.when you have an empty tub and put it on super load and fill it up there should be 12 to 14 inches of water in the tub. that is the normal operating settings for your washer.
Oct 03, 2011 | Frigidaire GLWS1349A Top Load Washer
The clothes are still wet after dry cycle is finished
Lift the washing machine and look underneath. Inspect the bottom of the gear case for evidence of oil. If oil is present, the oil may have leaked onto the spin clutch causing it to slip during your final spin. The transmission and clutch may need to be replaced.
Dec 19, 2010 | Washing Machines
Oil coming in the bottom of my washing machine tub.
Yor drum bearings are faulty and nee replaced Quite an expesive repair
Sep 27, 2009 | Whirlpool LSN1000LW Top Load Washer
Leaking oil from the bottom of the machine
Hi, Your problem is quite terminal, but easy to fix. You will need to replace the gearbox in the machine will cost around £150.00.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
Oil drip on bottom of gearcase Kenmore Model 110.21882 washer
Unless there is an abundance of oil this is normal.
If you tilted the machine to replace the coupling that could cause some oil to escape also.
There is a small hole in the top cover of the gearcase to release pressure. Sometimes a little oil comes out too.
Feb 25, 2009 | Kenmore 22622 Top Load Washer
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
Washing machine will not spin during spin cycle (it will if you give the drum a turn by hand)
Tilt the machine back enough to inspect the under side. Inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced.
Jun 29, 2008 | Whirlpool Washing Machines
Washing Machines Logo
205 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
