Question about Hoover Washing Machines
Hoover se147 cold wash flashing 8 times
Hoover SE 147 starts to fill fine then nothing after a while the cold wash light flashes 8 times Help!
  • mancompcompu
    mancompcompu Jan 17, 2013
    LOADS AND EMPTIES FINE
3 Suggested Answers
  • 3 Answers
SOURCE: hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
Posted on May 13, 2010
SOURCE: hoover vision HD 1400 AAA 8kg washing machine -
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Posted on Jul 18, 2010
My hoover 800rl top load washing machine does not progress beyond the fill cycle. once the water has reached the set level the start/ pause light goes from solid to flashing and nothing progresses form...
Check owner's manual. The light issue should be covered. Is it possible the tub is over filled? If so the level indicator switch is not working right. I'd unplug for overnight to see if the electronics will reset. Service Technician may be needed.
Feb 13, 2015 | Hoover Washing Machines
Hoover se147 washing machine fills with water then trips electricty
it has a short in it,could be the drain pump,or the wash motor or a bad fill vavle
Nov 10, 2014 | Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Dishwasher, not working
which 2 buttons flash?
Dec 05, 2007 | Dishwashers
Washing Machines Logo
73 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
