Question about Maytag Washing Machines
Maytag washer leaking below drum
Model #lat8006aae
  • Maytag Master
  • 17,130 Answers
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Posted on Jan 17, 2013
  • mark reinsel Jan 18, 2013
    thanks donald there was crack in the out let hose but didn't leak until it was agitating thank you very much
3 Suggested Answers
  • 714 Answers
SOURCE: GE Profile washer...model: WPRE6150HOWT sesr:
i'd check the drain pump-there is a seal where it attaches to the motor-leaks often there, also could be a leak in your tub seal between the tub and transmission, also sometimes the outter plastic tub gets a crack in it and leaks
Posted on Feb 15, 2010
  • 121 Answers
SOURCE: Maytag Washer LA7300 Water leak bottom of drum
This page will help http://www.appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 03, 2010
Drain pump will not drain tub,but if i place drain hose on ground,tub drains with full hose.is the pump belt drive,or transmission shaft driven.thanks bob
check underneath but normally the pump is a stand alone unit at the bottom of the tub
it gets its power from the program board when it is progressed from wash to spin
problems that stop it from working mostly come from items stuck in the pump impeller preventing the motor from spinning
look for coins , hair pins , bra wires etc that get lodged in the pump housing
Oct 18, 2016 | Maytag Washing Machines
My maytag washer model lat8006aae hot water flows in slow. I reversed water supply lines, no change, replaced water strainers and new water lines, still slow flow. supply lines, inlet water valve
It is possible the hot cold switch is flawed and stuck on mix of hot and cold I would have the inlet valve checked with a multi meter they can also check it for u at most appliance parts stores
Feb 07, 2015 | Maytag Washing Machines
Maytag model LAT8006AAE won't complete spinning water out. Stops and won't advance any farther. It does this on both long and short cycles.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 18, 2011 | Maytag Washing Machines
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Washer leaking from front
If I remember correctly, you need to remove the drum to get at the bolt that you are talking about. There is a rubber washer that provides the seal. The locking collar on the hub is Left hand thread. If you work at it you can get it loose.
Jul 12, 2008 | Maytag MAV2755A Top Load Washer
Large leak during wash cycle---Maytag - model LAT9520AAE top load washer
hey guys i guess this is not a uncommon problem. I have a commercial washer about 4 years old that get moderate service at a rental of mine and it is leaking from the tub as well. I hope to fix the problem because the new machines are very expensive.
Mar 22, 2007 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
267 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
