Question about Durabrand 7" Dual-Screen Car DVD Player
Will not stop loading
When I put a DVD in the player says it is loading but will not play. If I push "play" the screen will say play then immediately go to stop. Unit is charged up but simply will not play DVD's. (7" PDV 705)
0 characters
1 Points
DVD Bypass Codes w/ NO SWITCH
1- put dvd inside the video player
2- wait for blue screen to pop up and you should hear music begin playing
3-press stop twice on your remote
4-enter the code 26604
Dec 19, 2012 | Dual Xdvd8181 Cd/dvd/mp3/wma Motorized 7"...
I have a Venturer PVS 7287 dual player. The player we use most will play the sound but the screen is a blank white. We've tried different DVD'S with the same results.
Venturer PVS7287 Twin Mobile DVD Player 8" LDC Screens - I was getting a blue screen with the DVD not loading. I could see the ribbon cable was just slightly off from the side of the optic eye board. I gently pushed it back on with the tip of a screwdriver. I didn't have to take the player apart, as you you can see the optic eye and the cable that attaches to it when the door is open and the DVD removed. Be careful with the ribbon cable, it is very thin.
Apr 14, 2011 | Car Video Players
How do i bypass parking brake wire? do i connect to negative or
what color is the wire from the radio it might be pink or purple with white strip. but the wire needs to see ground or parking brake wire
Mar 07, 2010 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Disc loads, but won't play
Are these factory DVD's? Or burned ones? Als, are you loading te disc correctly. I have a PowerAcoustic and the DVD MUST be loadedupside down.
Larry T
Winona Lake, IN
Jan 26, 2009 | Boss DVD-7500 Car DVD Player
I have a Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player i can play music on it ,wen i insert a dvd the screen goes black i can hear the dvd playing on my speakers but no picture comes...
there is a safety brake wire that needs to be hooked up. If it was installed professionally, have them explain it to you.There is not supposed to be any video players in view of the driver while in motion. Stop your car and put on the parking brake. If you installed it yourself, you probably didnt hook up the wire. Look inthe install manual for DVD safety wire.
Dec 21, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
BackGorund Change on a Jensen VM9311TS In-Dash DVD player
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Sep 24, 2008 | Car Video Players
Audiovox D1020 DVD player
I opened up the dvd player & determined that the dvd was not spinning or took too long to start spinning, so the reader stopped. It looks like the arm that holds the dvd against the motor mount that turns it does not have enough strength to push against the dvd so that the motor mount does not spin without making the dvd spin with it.
For now, I'm using a small wooden prod inserted into the dvd slot to gently nudge the dvd to get it spinning. When the time comes that that doesn't work, I'll try to adjust the arm, but that's a last resort before I buy a new player.
Sep 18, 2008 | Audiovox D1020 Car DVD Player
Car DVD Player not working
hi sounds like its not reading your discs. try giving the dvd a clean and maybe try the DVD cleaning disc.
otherwise next stop repair agent.
Feb 23, 2008 | Car Video Players
Need Help with a 9311TS - viewing movies while the car is running
hi, i just bypassed my 9411 by doing the following. put dvd in the player wait until it loads,then push the stop button 2 times on the remote push 1264, on the right button push it twice down and in once...this should take you to the system setting there you want to turn off the brake overide on..push the left button once or just wait for the screen to return to the movie....I hope this works as good as it did for me...let me know.....later
Feb 13, 2007 | Jensen VM9510 Car DVD Player
Car Video Players Logo
35 people viewed this question
Top Durabrand Car Video Players Experts
matt martin
matt martin
Are you a Durabrand Car Video Player Expert? Answer questions, earn points and help others
