Question about Evenflo Chase Comfort Touch
Need new tether strap hook
Lost the clip on the tether strap that attaches the car seat to the back seat of the car in the forward facing position. Where can I get another one.
  • 25 Answers
Contact Evenflo's Parentlink Resource Center - contact info here. They can help you.
Posted on Feb 18, 2009
Cannot fold down my rear seat to access the child seat anchors. is there any way to release the rear seat from the boot?
Child Seat Restraints - FSB Forums - FullSizeBronco.com
www.fullsizebronco.com/forum/23.../182333-child-seat-restraints.html
Sep 22, 2010 - My rear seat hasnt been mounted in 6 years and my son Wyatt has ....Join Date: Oct 2006 .... Tether Strap Anchor Attachment for the Second Row Center Seating ... With the rear seat folded forward, remove the bolt retaining the rear ..... If you can't track down the part, send me a PM and I will get my Ford ...
Solution for car seat anchor tether - Tundra Solutions
www.tundrasolutions.com/.../119126-solution-for-car-seat-anchor-tether/
Dec 11, 2007 - I have a 2004 Tundra and I just installed a forward facing convertible carseat. It's almost impossible to get the tether strap attached to the ...
Child Car Seat Fitment in Trucks ' IH8MUD Forum
Dec 02, 2015 | 2006 Rover 75 Connoiseur
Combi instruction
It depends on your car seat. Follow your instruction manual for your child seat and your car. Not all seating positions have tether anchors.
"Rear-facing only" seats do not tether (these have a separate base and carrier)
"Rear-facing convertible" seats may tether.
"Forward-facing" seats usually tether (some MUST tether).
Jul 19, 2014 | Eddie Bauer Baby Gear
We need a tether can we purchase one?
The top tether should attached to the seat already. There is a storage back in the centre of the cover which it may be stored in. The universal anchor straps are attached as well and may be hidden under the cover where the child bum would be if sitting in the seat.
If you need tether anchor points installed (often in older vehicles), I would suggest you contact your dealership. I had 2 installed in my 98' as they are required in Canada for forward facing seats. It is often done free or at minimal cost.
Mar 12, 2011 | Britax Marathon
Bought used Britax Marathon and Roundabout carseats, without the manaul. Need directions on how to install- rear facing for now, but will need directions on forward facing as well.
Go to the Britax website they have a pretty detailed explaination. Basically use the latch clips put your knee in it and pull tight. where you get the real security is though the tether that comes of the back of the headrest, you attach that to the floor clip in your car or under the front seat if you dont have one.
Nov 05, 2009 | Britax Marathon
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Rear seat single latch
The latch that is on the top is called the tether strap. It is only used in the forward facing position.
Jul 06, 2008 | Eddie Bauer 3-In-1 with Latch
LATCH belt storage in rear position
 it definitely is NOT self explanitory as to where the LATCH is supposed to be anchored when not in use. It took some time, but I figured it out. The Top Tether should be hooked on the recline prop/foot/base area - depending on which way you have this positioned - for forward or rear-facing use, the piece to hook the top tether on could either be towards the front (rf mode) or back (ff mode). It's just a simple cut out in the plastic. The Lower Anhcors need to be clipped to a small plastic notch along the back side of the seat shell - you have to lift up the cover to get a good look at them - they are towards the top of the seat on the back and don't really look like much but do secure the lower anchors when attached.
I hope that helps! Please let us know if there is anything else we can assist you with.
Jun 21, 2008 | Maxi-Cosi Priori
Installation of Car Seat base
Try this link it seems very good http://www.aap.org/family/carseatguide.htm
May 13, 2007 | Cosco Travel Systems 01-938 Stroller
Evenflo Chase Comfort Touch Logo
363 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
