Washer will not spin dry enough for dryer
Whirlpool washer LSQ9564MQ0 will not spin dry unless I put dial on high spin and loosen basket, close door and repeat 2 or 3 times until dry enough for dryer.
  • Anonymous Feb 22, 2009
    I have a whirlpool washing machine that is not spinning at a sufficient speed to get the cloths dry. I have watched the spin cycle with the lid open and it seems to move too slow. When I activate the spin cycle with no cloths in the machine it goes much faster. Is there a belt that can be adjusted or is this a transmission issue?
  • 15,935 Answers
SThere is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer motor turns, drum does not
Please be gentle with me if this is obviously not the problem, but I have made the mistake of running top load washers with the door open (which the washer notices and does not turn the basket. I fixed my problem by loading the washer, adding the detergent while the washing machine was filling and then closing the door. My washer worked fine with the door closed.
Again, please be gentle with me as you rate my helpfulness. OK?
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not spin clothes "dry".
Lgm0923, we're sorry to learn of the experience that you've encountered with your Washer. Have you tried the troubleshooting suggestions on page 5 of your User Guide? The link is below. https://www.whirlpool.com/content/dam/global/documents/200311/owners-manual-3955869-RevB.pdf
If further assistance is needed, please email us your name, address, contact number, model and serial number at Whirlpool_Reviews@Whirlpool.com.
Oct 24, 2017 | Whirlpool CAP2761K Top Load Washer
Kenmore washer model 110.23812100. basket not spinning during spin cycle.
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23812100
Also see the Whirlpool Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you can hear the motor and the washer drains during the spin cycle the Motor Coupler and Lid Switch (the usual problems with these washers) are not the problem.
These washers use a clutch which allows the "basket tube" to spin up to speed during the spin cycle.
If the clutch bands or springs are worn or damaged, the transmission cannot transmit power to the basket tube for spining.
See the following on how to remove the cabinet,agitators, basket, pump, transmission and basket tube. (It's not as difficult as it sounds.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Instead of using a special spanner wrench on the spanner nut, I've used a short 10" pipe wrench hooked onto one of the tabs on the nut and tapped the handle with a hammer to loosen the nut. I also put a short piece of wood under the Basket Drive Block and hit the wood instead of the drive block directly.
Check the clutch bands and springs and the tabs on top of the basket tube and the slots in the basket drive block.
Nov 03, 2009 | Kenmore Washing Machines
I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
SLIPPING AND GRINDING
sounds like you have a bad drive block and possibly a bad basket drive I would stop useing it before you create damage to the basket drive. take the agetator off. sometimes they have a dispenser for fabric softner take it off or it will just have a cap remove the cap with a putty knife. next you will either see a bolt 11millimeter or you will see a hole that looks like a square. remove this and pull up on the agetator to takeit of next you will see a clip it will be somwhat greasy remove it. look at the shaft you will see a nut that screws the basket down to the drive block. If the drive block is raised up off of the basket drive sometimes you can hammer it back down onto the basket drive make sure that you line the ears up female on the drive block and male on the basket drive. Before hammering back down though you have to remove the spanner nut. But if you have been useing this like this you may need a basket drive and pretty much have to rebuild the whole washer. But I would start by hammering down the drive block or replacing it. let me know thanks //eg
Jan 12, 2009 | Whirlpool GSC9455 Top Load Washer
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
My direct drive washer spins slow
Always rule out first: Unsorted, too big or off balance load, too high or restricted drain, oversudsing or water not draining completely out before going into spin. Otherwise the brake could be not releasing fully or the clutch lining is worn. Pull the basket and transmission and check the basket drive.
Nov 11, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
463 people viewed this question
Top Washing Machines Experts
