Question about KitchenAid KP26M1X Stand Mixer
I have a kitchen aid mixer that turns fine, untill I put my bread hook in and try to make bread. then it gets stuck it stops turning. help what can I do
  • 4 Answers
I had the same issue and it probably is the worm gear. This youtube video is a great step by step guide to fix it.
http://www.youtube.com/watch?v=VeCiivPt7hk
The following link is to the parts diagram. If your model is different you will just need to search for its diagram.
http://www.ereplacementparts.com/kitchenaid-k5ss-mixer-parts-c-114958_114959_132766.html
it is a DIY project, a little messy, but worth it. The worm gear + SSH was only $5.50. A few hours of time and a fully functioning mixer again.
Posted on Dec 04, 2012
  • 142 Answers
Replace the brushes in the unit.
Posted on Jan 25, 2009
Why can't my kitchen aid mixer turn n
Sounds like the worm gear was stripped. This gear is designed to fail when the load on the motor is too great. This protects the motor from overheating and burning out. By the way, the mixer should not be used above the number 2 speed when using the dough hook.
The worm gear is not all that hard to replace although you will have to contend with a lot of grease. See the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 20, 2014 | KitchenAid 32685 Mixer
Kitchen aid mixer has a scream when using dough hook.
A little pin or setscrew or key has failed. Maybe a gear has slipped out of place. Anyway, the thing needs to come apart to find out what happened. When taking things apart, line up each item off in a tidy row, put screws in little containers near the part they fit.
Repairclinic.com may have instructions, and probably have the parts.
Nov 26, 2013 | KitchenAid Food Mixers
Motor head on Kitchen Aid KSM150PSWW is loose when in operation.
Are you engaging the head lock during operation? if not that is why it is loose. If you are it is not uncommon for the head to move around a little under heavy loads, when I make bread the head is always trying to come up so I have to use the head lock switch whenever I use the mixer on bread. It is the only time I lock it down.
Sep 05, 2013 | KitchenAid Kitchen Aid KSM150PSWW -...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Hello. I have a Kitchen Aid mixer made by Hobart between 1975 and 1978. It is a stand mixer with a 5-quart bowl that lifts and locks into place. While it was kneading a bread dough, the motor...
Hello Suzann,
I understand that you are having a problem with your Kitchen Aid 5 Quart mixer. It sounds like you have stripped the gears or the worm gear out. Although, it may not be an expensive parts repair it is not an easy task to complete if you are not mechanical enclined. There are many different little gears in these units.
My suggestion would be to take it a local appliance repair shop that works on mixers. If you can tell me the city that you live in I would be more than happy to give you the location of one or two repair shops. As the unit is so old you want to invest in a new unit and keep that one as a reminder of how long Kitchen Aid has been around.
Thank you for choosing FIxYa.com
Justin Burnett
Mar 16, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
109 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
