Question about Brother LS2020 Sewing Machine
I NEED A BOBIN AND ALEAVER THAT RAISES THE NEEDLE FOOT
THE MACHINE IS A VX1005 BICOR SEWING MACHINE
  • Brother Master
  • 7,365 Answers
Try these sites and see if they can help you,,you'll have to call or
email them
sewvacdoctor.com
a1sewingmachines.com
Posted on Jan 17, 2013
4 Suggested Answers
  • 980 Answers
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Posted on Nov 04, 2009
hazelgrace
  • 340 Answers
SOURCE: I still have my Bicor Sewing Machine, but lost the
You can download a copy for $5 from this site.
http://www.mastersewusa.com/info_bicorvx1005_2007.html
Printed manuals to the US are $12 and the rest of the world $17.
Hope this helps!
Posted on Oct 21, 2010
  • 14 Answers
SOURCE: Need Bicor vx1005 Manual
Unfortunatly it won't be free, as all websites I have found charge for the manual. MASTERSEWUSA.COM however was the least expensive, charging $5.00 for the manual. Hope this helps! Matthew
Posted on Jan 26, 2011
My singer machine 2263 is leaving long loops under the cloth.I have tried every thing but nothing works, can you help?
Be sure to use a brand new needle.
Remove the upper thread from the machine. ALWAYS RAISE the presser foot--this releases the tension disk so the thread will seat properly. Rethread the upper thread, making sure the path is correct.
Set the upper tension to the midway point (this is the standard starting point, but may need to be tweaked for your particular machine).
Now, retest your machine.
Oct 10, 2016 | Singer Sewing Machines
I just need to know where I can get the bobbin case for Brother Bicor VX1005. if not available, which bobbin case can be used in stead? I already checked ebay but I don't see it.
Contact your local Brother dealer or try the online Brother contact/support department. They should be able to provide you with the bobbin you need.
You can also try search some of the online sewing machine parts suppliers.
http://www.sewingpartsonline.com/
Sewing machines quilting machines embroidery machines vacuum cleaners...
Sep 23, 2015 | Brother Sewing Machines
Need a manual for the Bicor vx1005 sewing machine
I ordered the manual through http://www.mastersewusa.com but still do not have the download link. It has been almost a week now. The site said it would be in my e-mail in 3 hrs. Well today is day 5.
Feb 07, 2014 | Sewing Machines
How do you thread bobbin for Bicor VX1005?
Look through these threading guides for a Brother that has the same features. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
The above site has a manual, but I not a threading guide. Unless it is the same as another model.
Mar 07, 2010 | Brother LS-1520 Mechanical Sewing Machine
Presser foot lifter is stuck can i fix it
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Mar 31, 2009 | Brother LS-1520 Mechanical Sewing Machine
Thread from bobin doesn`t leave smooth sewing on bottom of fabric
hi make sure pressure foot is raised before you start to thread machine ortherwise thread will not slide between tension discs this will cause bunching underside of fabric ...good idea to replace needle good luck
mary h
Jan 05, 2009 | Husqvarna Viking 1
Thread bunching underneath fabric on Bicor VX1005 mahine.
The impulse is to blame the bobbin, because that's where the thread bunches. But the problem is probably with the top thread tension. The tension is too loose, allowing the bobbin to help itself to all the thread it wants. Retrace the path of the thread from spool to needle and see if you missed anything. The instructions in my VX1005 manual are not clear. I had to try a couple of paths before I got it right. Make sure the spring in the tension disk setup is moving freely. You should feel a fair amount of resistance when you pull on the needle thread. Hope this helps.
Terry
Nov 11, 2008 | Bernina Activa 130
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Brother LS2020 Sewing Machine Logo
107 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
