I have a used Sony SLV-920HF VCR that I am trying to set up. Every time I insert a tape it ejects it after a few seconds. Any idea why this happens?
Communication with TV functioned well during menu set-up. Tapes will not play due to auto eject after only a few seconds.
  • 5,259 Answers
There are two things that could be wrong. First damage to the carriage unit that holds the tape, which to me sounds most likely. The other a faulty or out of place mode switch, which could also could be caused by internal damage to any part of the mechanism.
Posted on Jan 16, 2013
  • mayerls
    mayerls Jan 18, 2013
    Thanks Gubhead for the quick response. I did not see any apparent damage to the carriage unit that holds the tape. Your other suggestion of finding a faulty or out of place mode switch is way over my head and I wouldn't know where to look. Thanks again for your help.
  •  Grubhead
    Grubhead Jan 18, 2013
    A mode switch controls all the functions of the video in that it tells the electronics what position the mechanism is in. I will post some pictures of them for you to look for the one in your video might look a bit different. If you find it with your amount of knowledge the best you can do is spray it with some Servisol Video 40. Which can be found online. It will take any dirt out of it. But it won't cure a broken or out of place one.
Vcr ejects tape when i try to record.
is the erase protection tab removed from the cassette?
if yes there is a square hole on the back of the tape visible when you insert it.
put a piece of sticky tape over this hole and make shure it does not come loose.
it should record fine now when you insert it again.
Aug 30, 2010 | Sony SLV-N51 VHS VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Sony slv-960 VCR cassette stuck inside
As your "free service" is not free I solved the problem by throwing the item into the trash.
Jun 25, 2009 | Sony SLV-675HF VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Code 3L117C ???
None that I could find. Trash time for this Sony
Dec 10, 2007 | Sony SLV-798HF VHS VCR
Sony vcr model slv-m91hf
make sure the tape is not missing its tab which is on the left hand side of the tape at the back
Dec 09, 2007 | Sony SLV-M91HF VHS VCR
Sony SLV-940HF automatically ejects tape.
1st try a different tape.
If it's the same, listen carefully for unusual noises, clunks, grinding, etc. when the tape goes in. Is something binding?
With the tape out, look inside the door, see if you can spot anything in there that shouldnt be there such as a small toy, money, playing card, sandwich, bits of food? Those are the usuals.
Turn the vcr upside down and holding the tape door open, tilt it so if there was a foreign object in there, it would fall out.
Oct 16, 2007 | Sony SLV-940HF VCR
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Video tape ejects itself
not to overlook the obvious but check to make sure the record safe tab is still on the tape. (little black tab on lower left corner on back of tape)if tab is gone the machine will not go into record mode.
Mar 11, 2007 | Sony SLV-ED85 VCR
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
