Question about Delta Tools & Hardware - Others
Delta bench top belt sander - Delta Tools & Hardware - Others
SOURCE: User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Posted on Oct 22, 2009
SOURCE: I have a Canadian tire model 55-3550-2 belt/disc
I went to a bearing/powertransmission supplier. The number on the belt was all they needed. Picked up a new belt for $6.50.
Posted on Nov 28, 2009
  • 122 Answers
SOURCE: My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Posted on Jan 30, 2010
agent91
  • 2100 Answers
SOURCE: I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
Posted on May 25, 2010
Testimonial: "Thank you for your help, now all I need to find is my manuel to break it down."
SOURCE: Finding parts for Craftsman 4x24 sander model
craftsman belt sander just stopped - does craftsman still have life time warrenty?
Posted on Aug 01, 2010
Change a disc on the 5" sander on the belt and disc sander item 10027
please be more specific!!
guessing - bench top disc/belt sanders' discs usually use stick on backed sand paper discs ;)
Jan 13, 2015 | Sander Tools & Hardware - Others
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
I have an Abbott & Ashby 200mm Industrial Bench Grinder - CS-8GCM I need to change the sanding belt and am unsure how to do it, can you help?
Remove/open cover on the right side of belt assembly housing. push downward on tracking knob left side top of unit.Belt is spring tensioned to remove slack.Push down remove old belt,push down again for new belt.With belt running adjust belt track(centering) by turning knob,top of unit,toward or away from you,Arrow on inside of new belt governs direction of rotation of belt.
Jun 09, 2010 | Sander 6" Bench Grinder 2" Belt Combo...
Should I buy an old Delta sanding Center? Is it wise to buy an older Delta sanding center 31-730F Not all parts are still available. They want $250.00 for the sander
If it's the kind with a round disk sander and a wide belt sander, as far as I know belts and disks are still available. There is not much else to wear out. Make sure you test it before purchase.
May 12, 2010 | Delta Machinery Sanders Sanding Center -...
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
On the Bench Oscillating Spindle Sander how do you lock the spindle so that you can remove the bolt at the top to change the sanding sleeve? When I try to loosen the bolt the spindle turns and I don't have...
Remove the spindle from the machine itself before you change the sanding sleeve. There should be a flat section on the bottom of each spindle that you can hook a wrench on to hold it while you undo the top bolt.
Mar 09, 2009 | Delta Machinery ShopMaster SA350K Bench...
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
USING MY DELTA #17-960 SCILLATING SANDER FOR THE FIRST TIME IN A LONG TIME. NO USER'S MANUAL.
OK you will have to contact a Dewalt Service Center, They do not have that manual online at this time. If there is still a problem and you cant locate let me know and I will try something else. I found a breakdown at Ereplacementparts.com but no user manual
Jan 01, 2009 | Delta Machinery ShopMaster SA350K Bench...
Tools & Hardware - Others Logo
27 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
