Question about Whirlpool LSQ8000 Top Load Washer
How do I remove inner tub on Frigidaire top load washer FWS845GC
I have removed outter tub top shroud and the 5 inner tub attaching bolts.
The tub will not lift out. Do I need to use more elbow grease because it is stuck, or, are their more bolts or hardware that I have missed?
Thank you for any help you can give
    New Friend:
I had the same problem
The trick is that the 5 bolts must not be removed.
Instead, the tub must be lifted with the metal base over the shaft.
See this video for detailed instructions :
Posted on Jan 20, 2014
  • 125 Answers
SOURCE: Frigidaire Washer - Loose Inner Tub
the inner drum is most likely broken. go to select appliances then select parts enter model number and you can get a blow up. Hope this helps.
Posted on Jan 31, 2008
  • 5911 Answers
SOURCE: Disassemble Whirlpool duet
Yes, but it is quite involved if you're up to the challenge. The following link explains the step-by-step details involved in removing the wash tub and spin basket:
I know this link is for replacing the rear tub bearing. The process is still the same, however, as it involves removing the entire tub shell assembly. There are no special tools required, but an electric screwdriver with socket attachments will make the process of separating the tub shell halves go much faster. I would also recommend that you order and replace the tub gasket if you are going to separate the tub halves. You can find a replacement gasket at Just type in your model number and look under the "Tub and Basket" heading for item number 10 (part #8181673). Other items to consider (but not mandatory) are the shocks for the tub (item number 23 - part #8182703). The shocks twist to release and they can sometimes break when you attempt to remove them. I hope you find this information helpful. If you have any questions, please let me know.
Posted on Oct 27, 2008
  • 18 Answers
SOURCE: Trying to remove inner tub of a Kenmore 60 series washer.
my friend had same problem with his machine. instead he filled it with boiling water and dumped a bottle of no name brand liquid plumber in and let it run through. the smell was fierce but it cleaned it out. this is probably not the smartest or safest way but it is easy. oh one more word VENTILATION!
Posted on Feb 23, 2009
  • 318 Answers
SOURCE: I am trying to clean out all the gunk that has
there is a special nut called a spanner nut. it is about 1 1/2 inches and needs special tool to remove it to get the inner tub out of the unit. you might be able to remove it with a pipe wrench and then you can get access to the outer tub.
i would recommend just using a washer cleaner and trying that first.
these chemical cleaners are designed to remove residues and are much easier then taking the unit apart.
  • 398 Answers
SOURCE: remove the top of the washer?
pull forward and pull up on the front to swing it( if you got all the screws out) , this usually works for most washers
Posted on Feb 26, 2009
Remove maytag inner tub
Remove top cover, take out the bolt remove the small cover to expose the plate with several screws,remove the screws and lift the inner tub up. Usually this requires two people to get the tub up and out as it is very hard to pull up as it kind of sticks to the shaft
Jul 02, 2015 | Maytag Atlantis MAV6000 Top Load Washer
How do I remove the drum on my aav7000aww
To remove the inner tub
remove front panel
remove screws holding top to cabinet
raise top
remove hoses from tub cover
remove tub cover
remove agitator
remove bolts holding inner tub to hub. 5-6 hex head bolts
lift off inner tub
Aug 20, 2011 | Maytag Washing Machines
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
We have a Frigidaire top loading, 8 cycle, heavy duty, super capacity 2 speed washer and it does not have a model number on the inside lid. The washer is leaking at the point where the drive shaft connects...
the part needed to be replaced is the main tub seal and it is not hard to do. remove the agitator the you will see a collars that has two bolts on the side of it this keeps the inner tub attached to the drive shaft you may also have one that is broken.
lift the washer lid. then remove the tub ring that is on top of the outer tub once this is removed you can remove the inner tub.there will be a brass ring with a black rubber piece in the center of it this need to come off in order to get the tub seal out. it maybe a little difficult toe remove but it just pulls up. you may have to use some liquid soap on the drive shaft to make things easier to slide up and off
Aug 28, 2010 | Frigidaire CWS3600AS Top Load Washer
Water leaking out of bottom of machine, nothing clogged and found a bolt head in tub
if you found the bold head in the tub chance are that the trunion bolt has broken off and cause the tub to become unsecure from the agistatir shaft and has torn the seal below the inner tub. remove the agitator and you will see the trunion and two bolts.the tub ring has to be removed and then the inner tub has to come out in order to replace tub seal.the tub seal part number is 5303279394 it cost around 45 dollars. the screws need for the locking plate are 131192800 and they caost about 4 dollars a piece.i hope this has helped you out.let me know how things go and if you need any more help let me know.
Jan 22, 2010 | Frigidaire FWSB5700DS Top Load Washer
Removing drum vane
No! Remove the screw holding the vane and slide it towards you. It will then come out.
May 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool "Roper" top-loading washer leaking
two screws hold back control panel on. panel flips up. two clips hold case on. remove clips and lid switch plug and whole outer case will tilt forward off machine base. pump is down in front and can be bought separate.
Apr 14, 2017 | Roper RAX4233PQ Top Load Washer
Worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
withoout asking why , heres how to remove the inner tub, simple enough. theres abolt in the top of the agitator,(pop the little cover with a screwdriver). the agitater pops off, insert a screw driver under the maintop perhaps 3 inches in from both sides and pop the clips the main top leans back. Unsnap the white cover from around the outer tub and lastly there will be (2)) 1/2inch screws screwed into asolid block at bottom of agitator, thay are locking the inner tub to the transmission shaft. note the flat spot on the transmission whish the block is resting youll need to reinstall it at same point
Mar 18, 2008 | Frigidaire FWS1339A Top Load Washer
Clunking noise and vibration during final spin cycle
For all those who say they recently bought the machine, the cause of the machine "walking across the floor" and vibrating violently is the packaging bolts on the back of the machine that were supposed to be removed when the machine was installed (why it says remove packaging bolts in the installation manual). These packaging bolts hold the suspension steady and firm during shipping but MUST be removed before operating the machine. When these packaging bolts (I think there are four total, some up to 6 inches long penetrate the rear of the machine) are removed, they allow the suspesion to absorb the vibration.
Feb 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LSQ8000 Top Load Washer Logo
672 people viewed this question
Dan Webster
Dan Webster
Sal De
